Pitch and Roll off?
JustinJ
Justin
Saskatoon
2024 Wrangler Sport 2D
Hello Jeep family,
It reads rolling 1 degree off to the left when parked on a completely flat ground after installing a spacer lift kit no matter driver in or not. I wonder if the lift kit caused it? Your Wranglers are accurate on this? Or it is just another Wrangler manufacturer imperfection?
My OCD is acting now…
Anyone has the same experience? Thanks for sharing folks!
Jeep Wrangler JL Pitch and Roll off? IMG_0735
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
The fuel tank is on the passenger side. Have you checked just after filling up?
Mine pretty much always read level until I lifted it, and then it was off the same as yours for about 8k miles and now sits level again. For me, I am assuming the springs needed to settle down a bit more, but for you, it should pretty much read level from the factory.
Might also be worth taking a look without sitting in the vehicle. It might just be body weight, or have someone jump in the passenger side as well and see if that levels things.
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
It's possible that one of the spacers isn't seated properly, i.e. the nipples on top of the rubber didn't align in the holes on one of them. That's just enough to set it off honestly. One of the springs could be clocked differently and might just need to be rotated in the seat.
wrang_stang
TX
Mine is always like that, I’ve noticed the same thing. Straight from the factory. Body weight would be an interesting explanation.
Zandcwhite
Zach
Patterson, ca
2019 jlur
If I recall correctly the stock springs are 155-185lbs per inch front and rear. That's a combined rate of 340lbs/inch. A driver that weighs half that would drop the drivers side about .5" I'm guessing that's good for at least 1⁰?
Badunit
VA
1997 TJ, 2023 JT
Hello Jeep family,
It always shows Rolling 1 degree off to the left when parked on a flat surface/ground after installing the spacer lift kit. I wonder if the lift kit caused it? Your wranglers are accurate on this? Or just another Wrangler manufacturer imperfection?
Years ago I had a friend who's mom drove a Cadillac, one of the big land yachts. The tire shop couldn't seem to get the front end aligned. Her son would bring the car in, they'd align it, but it continued to wear the tires. Finally, they asked how much his mother weighed. They had to align it with her in it. Does any of that apply here?
jadmt
jeff
montana
I just went out to check and my pitch and roll is not working at all. just dashes. that is with vehicle running.
JustinJ
JustinJ
Justin
Saskatoon
lol nope. I am a fit and cute fellow. So no. No way to be overweighted due to my weight
JustinJ
JustinJ
Justin
Saskatoon
Nope. I am fit and cute
JustinJ
JustinJ
Justin
Saskatoon
I think your Jeep is saying you're fat
You meant hung?
If no one is in the vehicle, ur wrangler still rolls or 0 degree? Just curious
Reinen
2021 Jeep Wrangler JL Rubicon
You would have to be a cute and fit dwarf to not impact the roll of the Jeep.
Try putting an equally sized person in the passenger seat and see if it balances back out.
Pape
Quebec
JLU Sahara
get one of those FAB digital angle reporter and see if the Jeep is really off. Quick search did not provide any dance move to have the angle to be relearned like the internal compass.
