Pitch and Roll off?
watchluvr4ever1116
Thomas
Michigan
May I know if yours rolls to the left with driver in or no? Is your Wrangler newer? Thanks for sharing
Just jumped in and drove it around the block, and back into my parking spot that is fairly level. it said 0 degrees roll. Jumped out and it was still showing same 0 degrees. I do remember it showing 1 degree with me in it on more than one occasion. I wonder if tire pressure could affect this or not? Otherwise it doesn’t really bother me.
dstevens
CA
2024 JLURX
1. Find the ESC module. It has to be on the centre axis of the vehicle so will be buried under the center console somewhere or under the shifter.
2. Shim up one side with a washer.
3. Profit.
JustinJ
JustinJ
Justin
Saskatoon
2024 Wrangler Sport 2D
3. Profit.
Not sure what do you mean? I am trying to find out if adding the spacer lift kit caused it or just another Wrangler common imperfection?
dstevens
CA
2024 JLURX
Apologies if I came across the wrong way, My point is that the ESC which is used for the pitch and roll reading has an accuracy as well and is just as likely to be incorrect as the spacer lift.
JustinJ
JustinJ
Justin
Saskatoon
Do you think with a 1* roll to the driver’s side (both when with and without driver in) is a big issue at all? I am not sure if the spacer lift kit caused it or the sensor has not been that accurate as we all know it’s a Wrangler…
Yours level well? Both pitch and roll show 0*?
Thanks a lot for sharing
dstevens
CA
2024 JLURX
I can check mine tomorrow, but first I'd have to get out the laser level and shim up the garage floor. I think the best approach would be to simple use a tape on the exposed portion of each shock and if they are the same declare it all good.
jadmt
jeff
montana
strangely mine started working again this morning. I have a 2.5 AEV lift and roll does not change whether in or out of the vehicle. 1° is not really enough to see with a naked eye. 1° is not worth worrying about. all jeeps have a bit of a lean.
Badunit
VA
1997 TJ, 2023 JT
Isn't 1 degree something like an inch from one side to the other? I'd think that would be noticeable if it was a problem with the lift. It would certainly be measurable.
Apexcars
North Texas
2020 RAM 1500
JustinJ
JustinJ
Justin
Saskatoon
Yeah I guess I am just OCD about it haha
JustinJ
JustinJ
Justin
Saskatoon
So you don’t think it’s due to the spacer lift kit? Otherwise would be too noticeable?
JustinJ
JustinJ
Justin
Saskatoon
The fuel tank is on the passenger side. Have you checked just after filling up?
Mine pretty much always read level until I lifted it, and then it was off the same as yours for about 8k miles and now sits level again. For me, I am assuming the springs needed to settle down a bit more, but for you, it should pretty much read level from the factory.
Might also be worth taking a look without sitting in the vehicle. It might just be body weight, or have someone jump in the passenger side as well and see if that levels things.
I think your experience is the closest to mine among all the replies. Well, I only got a basic spacer lift kit, no shock etc. I don’t know if I leave it as is, will it cause problem later on?
