I’ve heard of at least two people having codes and with turbosmart support it was still unresolved. One member here is using this with no issues. https://gfb.com.au/products/blow-off-and-diverter-valves/dv-plus/I have one in my 19 Rubicon JLU. Have ran it for about 2500 miles and zero issues. Feels more torquey off the line and quicker acceleration. I am going to be coupling it w the GoPedal and Turbosmart dual port blow off valve within the week. Mucho excited!
Go on...Piggy backs are 100% not worth it.
I had the same belief but a modern piggyback, that can intercept the can bus, has access to all sensor data and can do some pretty clever things.Piggy backs are 100% not worth it.
I don't think that makes piggybacks not worth it though, especially when there is currently no way to reflash the ECU (that I know of).Unless they’ve changed, piggy backs just intercept sensor data and modify it, tricking the ECU into doing things based on OE parameters.
Vs reflashing the ECU and creating new parameters (preferred tuning)
Honestly, I installed everything at once.. the Madness Max Pro, Madness flash (tune for more agrressice shift points), Go Pedal, S&B intake and Flowmaster Catback Exhaust so i can’t really give a review on just the max pro. I can say that their Bluetooth version of the Go Pedal has an issue connecting to Bluetooth. I tried 3 different ones and still couldn’t connect so I returned it and got the Pedal Commander which is working flawless. The flash you can tell the difference because It does “shift” gears a little later in the rpm.. as for the Max Pro, I’m not sure if I’m feeling any hp or torque from that or it’s just the Pedal Commander giving me that torquer feeling... I would go with one of those throttle controllers first and see if that alone will be enough for you.sj408_jlu - what are your thoughts on the Max Power Pro module now that you have been running it for a few months?
