Ordered Teraflex Delta BBK
Barney392
High Desert So Cal / Lake Havasu, AZ
yes i did, and i have screenshot now of it to the previous member. Seems like after the app forced me to update and the ABS Bleed is no where to be found
You might contact JScan and see what they say. You also remove the app from your phone and re-install...
[email protected]
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
[email protected]
I did couple hours back, and unfortunately the 4xe models dont have the abs bleed feature on the J Scan. However, i did log in using the regular JL models and boom the abs bleed feature was there and i wonder if i should do it through the regular jl model
mode.
Barney392
mode.
Don't know what to tell you on that one. Again, check with JScan and see what they say? There may be a good reason it's not there for the 4xe. Or maybe they just haven't tested it so it's not available.
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
Update: All 4 bleeders were leaking at 25ftlbs of torque. Teraflex advised to now torque to 30ftlbs. Thankfully i noticed this because the brake fluid got over my tires and wheels, and discolored my new nitto 38s (inner sidewall thread) almost yellowed it out. I have done over 10 manual bleeds over the course of post install and over 5 ABS bleed and still have a soft pedal. I have engaged the abs by going really fast on a dirt road and hitting the brakes hard.
However, if you have a lead foot or for some reason you like to hit the brakes hard it stops much better than stock, especially at high rate of speeds. Even with 4 stainless steel lines the pedal mushiness is identical to stock and with tad more brake down travel. But it is not real firm. I hope this helps anyone who wants to get these. Did i upgrade the brakes? yes most importantly it will save my life on the freeway before the car would just keep going. Now it feels like throwing a boat anchor as the boat is moving and sudden tug as it suddenly comes to a stop.
Barney392
mode.
Saw a JScan update for my Android phone today and it included the ABS Brake Bleed for the 4xe
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
Yes, thanks to me they finally used my cars log and date to create one. Also, it is exactly the same procedure as the Autel ABS Bleed. Whats so unique is that there is no opening the bleeder part during the ABS bleed as seen in the regular JLs.
It takes 10 minutes. It prompts you to manually bleed than Abs bleed followed by manual bleed. Heres direct quote on the most important steps: “Starting Boost Actuator Service Bleed control Phase”, “Starting Master Cylinder Service Bleed control Phase. This procedure requires 5 separate quick and firm presses of the brake pedal when instructed.” “Please press brake pedal to the floor rapidly and release it ONE TIME. This step will be repeated 5 times in close succession. Pedal press number: 0out of 5”.
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
Update: Torqued 30ft lbs all 4 corners and it dripped as in slow leaked again from the bleeder threads on all 4 corners. Anyone had similar issues?
Jeeps2Little
Lost in Utah
2021 Wrangler Sport S Unlimited 8spd
I wonder if teflon tape would solve the issue or if there is an issue with the tape and brake fluid?
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
i thought about that initially, but will see since i spoke again with Teraflex and now they want me to up the torque to 35ftlbs. Will update if it leaks.
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
Installed on 12/30/2024
SS Brake lines all 4 corner , Manual bleeding - Jscan Bleeding - Manual Bleeding test droved around 1-2 weeks my pedal got softer , Re-Bleeded including ABS another happy Jeeper here
Bleed Bolt : torque 20lbs only , do not over torque avoid Strip on the Bleeder..
Tips : Jscan Indicated ABS Bleeding on Right Side.. and then Ask You "Process Again?"
First ABS Bleeding to Left side and then Process Again to Right Side , i did this X 2
