Ordered Teraflex Delta BBK
Jeepula
Socal
24 Jl Rubicon X 4xe
Went ahead and ordered the full bbk.
Braking got worse after KMC beadlocks and Nitto TG 38s on my 24 rubicon 4xe (front stock pads have 6k miles and almost worn out).
Anyone have any long term review on this or different bbk? I was reading mixed reviews on the delta bbk and now got me thinking if I should just install good set of pads and call it a day?
Any advice would be appreciated, thank you.
Barney392
Lake Havasu, AZ
Installed the Teraflex brakes on my 392 about a year and a half ago. Couldn't be happier. What kind mixed reviews are you seeing?
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
thanks for the reply, was reading on how individuals didnt see a huge difference going from stock to bbk from teraflex. . My question would be to you if you felt a night and day difference ?
Barney392
Lake Havasu, AZ
Absolutely! The pedal travel is much less than stock and the pedal pressure required is almost non-existent. It does take some miles to get everything worn in but after that they are excellent.
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
thank you, i guess ill keep the order. Much needed feedback on the kit. Going to jump to 392 in the near future!
Blue Bear
Matthew
Seattle
2023 Hydro Blue JLUR
Air & Space Museum Curator
I've had mine for almost a year, and I love it. I switched to it not long after I switched to 37s, and I didn't like that the stock system couldn't keep up. A few times in traffic, I've had to hit the brakes hard, and the Jeep will nosedive from the braking power. My one complaint is the pads they give you squeak for MONTHS!
roaniecowpony
Retired Engineer
I'm 2 1/2 years on a set. I'd also recommend longer braided steel brake lines, etc., if you don't alread have them. I'm on 37s with a 3 1/2" Metalcloak lift and needed longer lines for the lift.
One of the best mods I've done. It stops like an Italian sports car now.
Eleven71Design
Richard
Fort Worth, TX
www.eleven71design.com
2022 Rubicon 392
CNC Manufacturing.
Running them with those XR wheels in your photo? Teraflex states they done fit with them but do not state which XR wheel version, 24/25 bolt.
roaniecowpony
Retired Engineer
I know they fit the Dirty Life 3.5" backspace
9310-7973MGD38CANYON9310
They also fit the Icon Rebound Pro 4.5" backspace.
Blue Bear
Matthew
Seattle
They also fit with Teraflex's Nomad wheel. I would hope so!
Barney392
Lake Havasu, AZ
Running the 392 XR wheels (25 bolts). Close fit but OK. The brakes will not work with the base 392 wheels (24 bolts) unless you add 1 1/4" spacers.
I am thinking of adding a 1/4" spacer with the XR wheels just to get a little more room. Not necessary though.
Hercules
Clearwater, FL
2012 Ram 2500 Longhorn, 2022 JLURD
Any idea if they’d fit method 701s 17x8.5; 5 on 5; 0 offset and 4.75 BS? I did the template , think it should work, just wondering if anyone else out there had my potential future setup
Barney392
Lake Havasu, AZ
Curious if you are a light braker? By that I mean do you coast to a stop with light brake pressure? I find if you do that a glase will developed on the pads and they will become squeaky. This goes for most pads. I am just the opposite and I've never heard a peep from the brakes.
You might lean on them a little harder and see if that helps. It will take some time to remove the glase so be patient.
roaniecowpony
Retired Engineer
No noise from mine. Nothing.
Jeepula
Jeepula
Socal
24 Jl Rubicon X 4xe
oh really, good to know, which brand did you go with or specifically part number?
