Oil changed = damaged fender
GrayHawk20
GrayHawk20
Cory
*See Signature for Info*
(Architectural) Jr. Project Coordinator
Sorry to hear about the damage to your Jeep.
This is one of many reasons I never go to the dealership for the "free" oil change. Too many times, the dealership has Jr. change the oil. Often, these 'mechanics' are new to the repair business and don't have any real skills. Just have never had any luck with the dealerships' oil changes. I usually either change the oil myself or have a local shop who lets me watch the oil being changed.
Where do you dispose of the old oil after you have changed it? That is my plan moving forward and going to the dealership for major items or warranty work in the future.
GrayHawk20
GrayHawk20
Cory
For several years now, one of the Service Advisors at our Honda dealer will walk around the vehicle with an iPod, filming its exterior condition. They do so almost immediately after the owner exits the vehicle after pulling it into one of the service reception lanes. The footage will serve to protect their interests, or the owner's, depending on the circumstances if (and when and where) damage has been discovered during the time that the vehicle is in the dealer's possession.
I think the foregoing is a good policy, one that possibly may have paid dividends in the case of the damaged fender being discussed here.
And there's the flaw in the slaw.
Cory, be prepared in case the dealer takes this very position. I'm not saying this to be accusatory, but rather to suggest what might [unfortunately] happen.
Best of luck as you seek resolution here.
I have pictures before sending there, ive only owned it since Wednesday and it something like that I would have noticed scratches and marks like that. After the dealership it stayed in the garage all day, so it was on the dealers part.
miweber929
Michael
Woodbury, MN
‘21 JLU Sport S, ‘16 Silverado
Any oil change place will take it, Walmart usually does, otherwise your local recycling center will as well.
Heimkehr
Pennsylvania
2021 JLU 2.0T
I do agree with an earlier comment suggesting that the fender damage had the appearance of a footprint. That someone might have used the fender for that much weight-bearing might make me see red. So, again, good luck with the resolution process.
I can confirm that Advance Auto and Auto Zone will accept used motor oil, provided they don't have a "Tank full" sign taped to the door the day you go there. I give my used oil to a local, independent mechanic who, I believe, heats his shop with waste oil. I've never been charged when dropping off used oil, either.
GrayHawk20
GrayHawk20
Cory
Good to know, thanks very much.
GrayHawk20
GrayHawk20
Cory
I can confirm that Advance Auto and Auto Zone will accept used motor oil, provided they don't have a "Tank full" sign taped to the door the day you go there. I give my used oil to a local garage that, I think, heats their shop with waste oil. I've never been charged when dropping off used oil, either.
Thanks for the tip, I should have caught when I was at the dealer, but honestly didnt even cross my mine as I have dealt with this dealership for years with servicing. I will now be taking good before pictures before heading to the dealership.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Either drop it at Autozone or get the burn pile going real good.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
…how do you damage a fender during an oil change let alone not clean up after yourself.
It's easy, they try harder.
Sorry about all of the damage. This is why at 70 years of age, I still do all of my maintenance work. And it gets done right. Without damage.
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
I just dropped off a big container of oil and ATF at AutoZone this afternoon.
GrayHawk20
GrayHawk20
Cory
I will be doing it myself, not sure how hard it is with a 6.4L engine under the hood.
calemasters
Allen
Springfield, Mo.
By the way, did you check the engine oil level to make sure it is correct?
Heimkehr
Pennsylvania
2021 JLU 2.0T
What matters is ease of access to the drain plug and especially the oil filter when under the vehicle. The former should be front and center, so to speak. I don't know where the latter is on the 392; I'd actually ask an owner like you for a photo if I needed to confirm where it is. ;)
The oil fill cap should be plainly evident up top.
Yes, double-check the dipstick to determine if the dealer at least got the fill quantity correct.
GrayHawk20
GrayHawk20
Cory
Ill have to look in the morning and check the oil dipstick, had other errands that I was running (not in my 392). This one simple oil change, that ive had no other issues with at this dealer is making me question everything, I figured it would happen sooner or later to me to have a bad dealer experience.
GrayHawk20
GrayHawk20
Cory
Yes, double-check the dipstick to determine if they at least got the fill quantity correct.
Id like to check the dipstick who worked on my Jeep.
GrayHawk20
GrayHawk20
Cory
Want to thank everyone for the advice for my servicing going forward on this Jeep and any future Jeeps, I figured id run into a bad dealership experience sooner or later. I guess it was sooner than later.
