Jeep Wave/oil change ?
Pig-Pen
Banned Camp
2018 JLU
jabroni
Love your information, it was well presented and informative. Yes if capable, do it yourself it very easy and with the jeep design, high access height you can just craw under. I won't even have my local dealership change the oil even though I had free oil changes. They are basically inept beyond believe. I'm sure they would put in 6 quarts as well as the wrong weight. The 0W20 is specified for a good reason. These engines are build to a closer tolerance and need the thinner oil for lubrication.
personally i think the 0W is for mpg. Thicker oil can actually hurt your mpg slightly. Fiat did everything they could to squeeze out every extra .0001% of mpg on the JLs.
and we’re all busy busting that mpg right back down with bigger tires, lifts, and more weight! :jk:
iznthesky
Edgar
Humble, TX, USA, EARTH, Milky Way Galaxy
2018 Jeep JL Rubicon & 2004 Jeep TJ. Previously owned 1993 Cherokee, 1980 CJ5, & M151A2 while in the Military. For the love of Jeeps !
Do it yourself. Super easy (easiest of any vehicle I have ever owned) and you’ll know it’s done right. (Or if you mess up, at least you have only yourself to blame. It happens: https://www.jlwranglerforums.com/forum/threads/oil-filter-o-ring-placement-matters.34840/ )
Besides the inconvenience of going to the dealer, too many of them are putting in 6qts of oil (because that’s what the 3.6L V6 took in the previous generation).
A 5 tire rotation is very easy as it only requires that one wheel be jacked at a time.
Here’s the note I keep on my iPhone to keep things easy:
Oil:
5q 0w20
Oil Filter:
MOPAR MO-349 68191349AB/AC
Mobil 1: M1C-456A
Air Filter:
MOPAR 68257030AA
8mm socket
Cabin Filter:
MOPAR 68301863AA
Tools:
22mm lugs
13mm drain plug
24mm oil filter cap (torqued to 18lbs)
Pull F11 & F97 to reset UConnect
(Edit: this is not a maintenance item, just a “note to self”)
Thank you......of all the information on this forum....most of it is good information....but your posting provides GREAT maintenance info at our fingertips. This is good to have handy.
Great tip on having it on the phone.
THANKS
HealthRebel
Jerry
Colleyville, TX
2020 JLRU Ocean Blue
I agree 100%. The 0w is for increased gas mileage, which saves FCA money. I do not feel it gives the best protection for the 3.6 V6, especially past the warranty.
JSFoster75
Bluff City, TN
I change my own oil now, but for my freebies I did this......
worked great.... $ 5.00 on Amazon, by far my cheapest and easiest, but most effective mod so far. Also it’s for me, since I change my oil in my ram work truck, same engine but takes 6 quarts... :facepalm:.....:).
link please?
Roky
Roky
link please?
Jeep Wrangler JL Jeep Wave/oil change ? 74EA665D-6353-4963-8231-CFA645E54A4E
I don’t know how to put up those yellow link things on my iPhone, not very computer savoy, this is best I can do, I need to take a class or something....:facepalm:.....:)
JSFoster75
Bluff City, TN
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
blnewt
New Mexico
Just ask @cosine he knows!
THANKS
All good info, but for the oil drain plug a 1/2" socket, and the oil filter cover a 15/16" are tight, the metrics have some slop there.
Jeepney18
Bay Area, California
2008 Toyota Corolla S, 2018 JL Sport S Unlimited
It's over the limit. I'm going to have to drain it.
I finally got some calls returned. They're saying the paperwork is incorrect and that they really put 5 quarts. I checked the dipstick and according to the picture, they're just lying to me at this point.
I did remove oil that night and it's at the top level of the dipstick. I'll take advantage of the free oil changes but will double check again next time.
higbyz
vermont
2018 sahara mojito 2.0 - 2020 Sahara Bikini 2.0
Get one of these pumps and simply suck the oil out. Much much easier
Jeep Wrangler JL Jeep Wave/oil change ? pum
Crusifix
West Virginia
2019 JLU Rubicon 2.0T Hurricane
I agree with that. On my wife's old LR4, it was the only way that you could change the oil. I use that pump for all kinds of stuff.
AJR2025
Lansing, Michigan
JLU Sport S
Had my Jeep wave oil change done today at Lafontaine in Lansing, Mi. The invoice says they put in 6 quarts. I questioned them. I was told that the “manual is wrong, that their system had been updated and calls for 5.5 quarts. The computer system only allows them to itemize whole numbers. That’s why it says 6” . On top of that, they installed the steering damper backwards. “The steering damper can go both ways”. If that’s the case, why put a sticker on it indicating the proper direction?
Snayte
Nathan
Eau Claire, WI
2019 JL Sahara Hella Yella, 2017 Ram 1500 Longhorn
Hey, I grew up in Lansing left about 30 years ago though.
00Sebby
Knoxville, TN
2020 JLUR
Ex-auto quality engr & mgt. Now just enjoy life.
I took mine in for it's first Jeep Wave oil change. I also took my own Castrol Syntec 0W20 because they were only going to use a synthetic blend. So it cost me $25 for the 5qt jug at Walmart. I talked to the oil tech and he knew JLs are 5 qts. I joking told him he can only use the contents of that jug and nothing else. Fortunately I was able to watch through the window and everything went well. Oil level was near the top of the indented area on the dipstick. The tech had previously worked at the dealership owner's Audi dealership and seemed to do a good job. Whew!
johnparjr
New Caney, TX
2024 Jeep Wrangler Sahara 4xe
Just went in for my second oil change after the last one 6 moths ago where I argued that they over filled it and contacted Jeep about it which they promised to address it with the dealer. And lo and behold they got it right the paperwork says 5 and the oil stick looks good
