WranglerMan
- Will
- May 8, 2018
- Greenfield Indiana
- 2018 Wrangler JLU Sahara
- Occupation
- Retired
- Vehicle Showcase
- 1
Well, I spoke too soon. Just went out to run some errands and sure enough ORP are gone.I realize this thread my have gotten a bit sidetracked, so to steer things back - yes the OBD JSCAN app can activate ORP for those with an 8.4" radio.
Nope. It’s a known issue. Off road pages will come back on their own. Mine are back now.Is there some type of registration I have to do or something?
So I guess there is not anything I can do to restart it?Nope. It’s a known issue. Off road pages will come back on their own. Mine are back now.
You can try pulling the fuse for the radio. Lift the hood and pop the cover for the fuse box. Look under the cover for the location of the radio fuse. In my opinion, it’s not worth the effort. There’s nothing special about the Off Road Pages.So I guess there is not anything I can do to restart it?
While your JL is running, pull fuse F97 for 10 seconds and then reinsert the fuse.. This reboots UConnect and may hurry up the return of Off Road Pages when it goes AOL.So I guess there is not anything I can do to restart it?
@jludaveYou can try pulling the fuse for the radio. Lift the hood and pop the cover for the fuse box. Look under the cover for the location of the radio fuse. In my opinion, it’s not worth the effort. There’s nothing special about the Off Road Pages.
I need little help on activating ORP.
I switched from 7" to 8.4" and I have J-scan but I cannot find which menu to go to activate it. ><
Like J-scan but sometimes the procedure is a bit of pain.
THX
I want to do a few basic changes To my 2022 JLR like TPMS limits. Do you have a recommendation as to which OBD2 scanner I should buy? I am kind of leaning toward the vgate icar pro or the Vlinker MC. Since I will probably not do basic things, I do not want to buy an expensive one. Thanks@jludave not sure what OBDII BT module you are using but I have several I’m testing and OBDLINK has a killer good app, no it’s no Off Road Pages but it gives you a ton of info on the Jeep.
@GmanjeeperI want to do a few basic changes To my 2022 JLR like TPMS limits. Do you have a recommendation as to which OBD2 scanner I should buy? I am kind of leaning toward the vgate icar pro or the Vlinker MC. Since I will probably not do basic things, I do not want to buy an expensive one. Thanks
Thanks. i am curious. Why does the person at this link recommend the module (for example, ERC1) over the cables referenced by this JSCAN person? Is the module just a lot more convenient? Thanks again.
