Newbie with DW issues
mtglick
LA-ish
2020 JLU Sport
Hey, all--newbie looking for assistance with next steps. Experiencing moderate DW with my 20 JLU Sport 6-speed. Am in the middle of the process and hoping someone can point me in the most efficient direction from here.
I'm the 2nd owner, 21K miles, truck is on what appears to be a factory 2.5" lift (the Fox one) on 33" K02s. DW is not a light shimmy or a subtle vibration--it's a full-on shake. Have upgraded a couple of parts, and have succeeded in CHANGING the problem, but not fixing it.
Initial issue appeared about 2K miles ago or so--anything that upsets the front axle can trigger the shake, but generally only at or around highway speeds (+50 mph). Outside temp seems to be a factor--colder temps are more likely to incur a DW. Triggers most often in slow left turns when going over expansion seams on the highway. Does NOT self-generate, it needs that little bit of bump steer to get itself going.
Went through the internets, read boards here and elsewhere, and got a little more informed about the problem. Got under and pulled and tugged on everything remotely steering-oriented. Did not lift the Jeep and check without weight on the suspension, but ultimately, nothing looked all that much out of line, end links had no play, and nothing looked horribly out of shape, etc. Did the "watch underneath while somebody turns the wheel" process, but didn't see anything unusual or out-of-line Admittedly, my mechanical skills sort of top out at changing out radiators and plugs, so I simply may not have been able to identify any issues on sight.
After that, decided to replace the high-probability fail points to see if that would solve it. Upgraded the track bar, steering stabilizer, and ball joints with aftermarket pieces. If it matters, the new track bar is a Core 4X4 Camp, the SS is the Icon centerline, and the ball joints are the Metalcloak Ballers. All professionally installed at a tire and suspension shop, and (presumably) all done correctly, torqued to spec, etc. Just to note, I did NOT have the wheels rebalanced. However, I do know what unbalanced normally feels like, and not experiencing any other shimmy or shake--ONLY when the axle gets bumped out of line.
First and foremost, those three upgrades made a HUGE difference in the steering quality. Night and day. Highly recommend those changes to anyone reading. I have no idea why, but the truck actually pulls slightly harder off the line (SOTP, but it's noticeable--I'm getting out of first gear a little quicker). Steering is light, crisp, and precise. Just a massive upgrade and makes the truck that much more enjoyable to drive.
Unfortunately, the upgrades did not solve my DW problem--but it changed. Where it originally only took a slight bump to get the DW going, it now takes a somewhat harder "hit" to start it shaking. However, that also means the shake is proportionately more violent--more energy in, more energy out.
Before I pull the trigger and just rebuild the entire front end (tie rod, links, drag, UCA/LCAs, etc.), I thought I'd ask if anyone has a more targeted thought here--does the fact that the new track bar, SS, and ball joints failed to fix the issue, but did change it, point to one part or parts being more suspect than others? Or should I just tear it all down and start over?
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I'm not an expert but from what I've seen the drag link would be my next step. There are some good death wobble videos on YouTube, it seems like upgraded steering parts will fix this even without a stabilizer. The track bar seemed to be the fix for me.
Barney392
Lake Havasu, AZ
Do you have the aluminum (natural aluminum color) or the cast iron (painted black) steering box?
mtglick
LA-ish
2020 JLU Sport
I believe there is a recall on the aluminum steering boxes. Too much flexing that could cause your problem. Might check with your dealer on that.
I guess it's not a recall but a TSB.
https://www.jlwranglerforums.com/fo...b-08-074-20-for-improved-steering-feel.56363/
I did see that elsewhere, but it didn't seem to relate--specifically stated in the TSB I found that vibration was contraindicated for the TSB. If I read it correctly, that was supposed to be for wandering in warm temps.
Also saw someplace there was a brace for the steering box, but didn't get very far down that path--thought there were other, more potentially impactful points to investigate. But open to hearing otherwise!
Themistocles
Virginia
'03 Ram 2500 Cummins / 20 JLURD
Concur with everyone's comments above, especially replacing the aluminum steering box. I might add in a sector shaft brace. Also recommend going through and checking the torque on all fasteners even mildly related to steering. I chased this same problem on my 2020 JLURD and eliminated it with (Fox Steering Stabilizer, Dynatrac ball joints, Reid Racing steering knuckles, Steer Smarts sector shaft brace, replacing the aluminum steering box, and retorquing everything.
Good Luck!
Barney392
Lake Havasu, AZ
You might tell the dealer you have the symptom's stated in the TSB. The cast iron box is much stronger than the aluminum. Never know, it may help your problem.
"SYMPTOM/CONDITION: The customer may describe one or more of the following: • Steering wander. • Vehicle has a lead/pull to the right or left."
Yawnie'sPapa
Bill
Central Iowa
'22 JTO, '23 JLUR, '82 SX4, '73 P. Cardin Javelin
I'd still be suspect of the tires - you'd be surprised at how many have either changed tires, or had a good road force balance job done and said - hey, it's apparently resolved.
If that thing is out of balance, you hit a bump and it's like a spinning top.
We've proven in other jeep areas that tires and tire imbalance can indeed affect DW.
The problem with the aluminum steering gear was more play, slop, than anything else. The box housing is just as stout or stiff and it isn't "flexing" if that's what people are implying.
It will help wander or a loose steering feel and take "play" out of the system because it's got internal issues, but it's not at all because it's aluminum. It's not bending or flexing.
They just happened to go back to a cast steel housing for the new gear is all.
mtglick
LA-ish
2020 JLU Sport
Thanks, all. Helpful stuff. Will keep apprised as I go.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
The steering TSB pretty explicitly states that it will not address a "sustained shimmy or shake" or something to that effect. What SS are you using?
mtglick
LA-ish
2020 JLU Sport
Understood. Using the ICON Centerline SS.
Couple things that did pop up--while the drag link doesn't have side to side play, or front-back play, it DOES rotate through about 10-15 degrees. Not sure if that's by design, or an issue. Also, the tie rod has a minor deflection at the adjustable end. It's solid, but the adjustable portion of the bar is not flush-seated into the body of the tie rod--there's about a 15 degree angle at the point where they meet.
Normally I hate the parts shotgun, but the moving-target nature of this leads me to believe that ultimately, until everything is right, nothing will be. So I ordered some more parts from MetalCloak, and will have the tires rebalanced when I get these added on. New tie rod, new drag link, and the sector shaft brace going on.
As to the TSB, I also spoke to the dealer, who is a nightmare under normal circumstances (and I don't have the best relationship with them as it stands), and got an outlandish quote to replace the steering box. Nope. Am considering a steering box rebuild kit, to replace the gears, or just finding a better part and getting that installed, if the above doesn't effectively handle the problem.
mwilk012
Oklahoma
Service
Rotation of the drag link and tie rod ends is normal.
