Heimkehr
Pennsylvania
2021 JLU 2.0T
We can utterly trash these engines by putting the spark plug in the wrong place, but potentially also by simply using insufficient octane?
That's the question, John.
The more we know, the better informed our future purchase decisions will be.
alphawolff
california
2021 JLU
Current consensus is these engines are suffering from extreme knock at 87 octane.
The vehicle legally needs to be able to run (i.e. function within emission requirements) on 87. Not really sure what their solution is going to be but this seems to be a widespread issue at the moment. Most are breaking within the first 200 miles, some right off the delivery truck. This seem very odd considering this engine would've undergone trial testing well before being put into service. I wonder if they changed something last minute or installed something improperly at the factory. It could also of been a PCM tuning issue with improper ignition timing.
Currently we're being required to replace all 8 plugs as a set and send pictures to corporate alongside the claim.
At the end of a day this is a turbo 4 banger making 324HP/330tq yoinking along a 3 ton vehicle. Even attempting to run 87 on it is ludicrous, but your average soccer mom is going to put the cheapest shit possible in it. Very curious to see what the final solution is.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
What typically has to be replaced, just the plugs?
2nd 392
Ca
Interesting “legally” , is that because Stella didn’t want to make it 91 required and scaring potential customers off ? … So you replace the plugs, detonation kills them again running 87, they better figure it out quickly.
alphawolff
california
2021 JLU
All eight plugs, and if the white porcelain or electrode is missing you have to replace the engine.
I'm hearing from other techs they indeed replace plugs and it comes back a few hundred miles later. And yeah, LEGALLY all road emissions compliant vehicles much MEET emission requirements at 87 octane. This means no misfiring.
2nd 392
Ca
I’m still confused, 392’s 91 required. I’ll go out on a limb with Hellcat’s 91, also other performance vehicles.
alphawolff
california
2021 JLU
You can run 87 in your 392 and it'll meet federal emission requirements. It might right like shit, but it'll still meet those requirements. It'll probably pull as much timing as it possibly can to make that happen.
alphawolff
california
2021 JLU
Jeep Wrangler JL New Jeep 2.0T Hurricane 4 has complex tech [Engineering Explained] 1781299094083-q5
New interim guidance is to only run 91+ octane in this engine until further notice 🤣
I suspect we will get a recall for a PCM update alongside spark plug replacement once this all settles. The PCM update will probably de-tune the engine significantly on less than premium fuel. They should probably just advertise the engine like Mazda does, with two separate power figures for octane levels.
croppz
Zach
North Carolina
2021 JLU Rubicon 2.0T
It’s kinda crazy they didn’t learn from the old 2.0T? Or any other small displacement TGDI engine on the market for that matter.
Dusty Dude
Colorado Springs, CO
Next stupid question: Were these customers using E15 fuel, fuel from a 7-11, etc?
How in the hell did they not program this “marvel of engineering” properly before releasing it to the public?
Guv
2018 Wrangler Sport 2.0 E-Torque 2 Door
They could give it a good safe 87 tune but not at the same EPA fuel economy rating. Retarded ignition timing requires over fueling to keep exhaust temperatures in spec. Neither change is going to work well for maintaining fuel efficiency let alone performance.
You can only get so much from a small engine especially when you’re handcuffing it with low octane fuel. Someone at Stella should have given this a little more thought, especially considering the projected buyers hauling around soccer balls.
alphawolff
california
2021 JLU
These vehicles are blowing up within the first 200 miles. Quite literally fuel from the dealership purchase. Some were even damaged right off the delivery truck.
2nd 392
Ca
Do keep us informed of how they deal with the remaining fuel in the tanks.
