Need alignment?
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
I was going to say basically the same thing as stumblinhorse. Your "alignment" doesn't change with a spacer lift, except for caster, which isn't adjustable (they can't adjust it to be within spec).
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
I put 1.75 inch blocks in front and 1 inch in the back to return to level on a 2021 JLUR after putting on bumpers and winch. I didn't get an alignment and everything is fine 35000 miles later.
Roky
Roky
Local mechanic stating he will not install leveling kit without doing an alignment. Mission critical? I was under the impression after reading many posts here that the truck may not need the alignment. Only do if absolutely needed. Thoughts? Thanks1
As these guys stated (several times) not needed ….I’m responding to tell you not to use that mechanic, he’s either trying to milk you for every penny, or he doesn’t realize that alignment isn’t necessary….. either way it’s a red flag and I wouldn’t let him touch it…… I recommend you do it yourself if that’s at all an option….. There’s a lot of us on here that can walk you through it……when you’re done you’ll have a way better understanding of your rig that will pay off in the future……
Zandcwhite
Zach
Patterson, ca
2019 jlur
Spacer only install means there is 0 need for alignment. Caster will be down but with fixed stock or even aftermarket arms it can't be adjusted. Toe is adjustable but will not change as the steering wasn't touched. The steering wheel will need centered but that is not an alignment and should be included in any lift install. Now with the price they are charging it wouldn't hurt as maybe toe was off before the install and it will be good to know how bad your caster is to determine if adding lower control arms needs to move up the to do list. I just hate the wording of it being mandatory.
Bam073
Bam073
Long Island, NY
2019 Jeep Wrangler Unlimited Sport Altitude
Mechanic specializes in Jeeps. Quoted price was $300 with an alignment which still seems fair. Of course I'd prefer to do for less without the alignment.
Appreciate the advice of doing it myself. Going to try to speak to my neighbor who has all of the tools needed. Thanks again Roky...
Old Jeeper
Don
US Army Infantry, IT Engineer
Alignment (IF NEEDED) AFTER the leveling kit!
Old Jeeper
Don
Thanks Old Jeeper. Love the name!
I am OLD, heck I listen to W OLD Radio, but the other day somebody said there a TV thing???
Bam073
Bam073
Long Island, NY
Check out what's called the world wide web! Amazing access to information quickly. Life changing!!! Then again I just turned 50 this year so I'm not too young.
Old Jeeper
Don
I am knocking on the door of 80...BUT been on the net since 1979 when it was called ARPA-DARPA Net!
Old Jeeper
Don
God bless you!!! Keep doing your thing.
I do, just came off a 6 week 3600 mi business trip and in 10 days leaving on another one...that will rap it for the year it will be late spring before I do another one...got to go, to get my F 450 truck in the shop for them to redo what the did yesterday...
Bam073
Bam073
Long Island, NY
Neighbor and I tackled last night (rear) and this morning (front). Only broke up because life gets in the way. Used jack stands and jack and while I won't say it was easy, it wasn't too difficult. My neighbor was the lead and I played helper. Does not appear as if I picked up a full 1.50" however it does look noticeably higher. On to the next thing!
word302
Oregon
JLU
With spacers you picked up exactly what you put in.
