Need advice for steering stabilizer
Q’s JLUR
Quen
North Carolina
2019 Unlimited Rubicon
Lead Engineer
19 JLUR with 35 inch tires and just installed the Teraflex 2.5” performance spacer Lift. Looking for recommendations for an upgraded steering stabilizer. I can spend up to $350 if needed but I don’t feel like I need an adjustable stabilizer for 35” tires.
Any insight on brands and models would be greatly appreciated. Thanks
-Q
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Chipe
Chip
CT
Silverado
You could just stick with Teraflex. They would work well together.
Arterius2
Jerry
Vancouver, BC
KPsrq
Sarasota, FL
18 JLU Rubicon
I have the Teraflex adjustable stabilizer and tbh it’s wonderful. All 3 settings are noticeably different. Every day driving I use medium, if I’m highway only I use firm, if I’m feeling lazy then I use soft.
The best part is that the Jeep already had it on there from the previous owner
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Has anyone found a good way to mount the JL version above the tie rod? I've been considering the ATS but only if I get mount it out of the way of rocks.
You can purchase the JK version with the 1-5/8 clamp. We didn't have issues on our 2dr JL with stock draglink/tie rod, but we run fairly tall bumpstops with the coilovers.
Q’s JLUR
Q’s JLUR
Quen
North Carolina
Lead Engineer
Q’s JLUR
Q’s JLUR
Quen
North Carolina
Lead Engineer
Did your steering start feeling loose after the lift? If so, it is more likely a caster issue. Steering stabilizer is not the cure.
Hey Carlton,
Steering doesn’t feel too loose. I had a 4 wheel alignment from an expert here that I trust. He corrected as much as he could but showed me how the spacer lifts on the JL still create a little angle to the right. It came out to .108 degrees overall and it’s in the rear only but I don’t feel like that’s what I’m feeling. .108 is basically nothing.
I think what I’m feeling is normal for 35” tires and no upgrades steering stabilizer....I hope haha.
Q’s JLUR
Q’s JLUR
Quen
North Carolina
Lead Engineer
So I’ve seen a few replies about the Adjustable Fox Racing one. It looks super nice. Question, how difficult is it to install/adjust?
Carlton
Chicago
Jeeps lots of jeeps
Hey Carlton,
Do you know what your caster numbers are?
