Mud flaps?
ArcadeTracks
PJ
Pittsburgh, PA, USA
I'm thinking mud flaps (mudflaps?) will be one of the first things I install on my Rubicon. It's going to be an everyday driver with off-roading when I can -- probably increasing in frequency as I learn what I'm doing out there.
I was planning to get a cheap (<$25) set for front and rear. Front to protect my doors, and rear to protect other drivers. (I've head some windshields crack rather easily with hits even from small rocks. ;))
If they break when I go off-roading, I'll just replace them. It doesn't seem like they are likely to damage the actual vehicle + I've read they are appreciated by other drivers in some off-road situations.
Does that sound about right?
(Certainly not a big important question/topic, and I've already found some info on it. But I'm still waiting for my Jeep to arrive, so this is how I choose to spend my time...)
Javwohl
Denver
17 vw gti, 2001 dodge ram, 202 jlurd white, 2005 mazdaspeed Miata lava orange
engineer
Lol I just got my set of Rokblokz xl in yesterday. The pile just keeps getting bigger.
LKG
Larry
Boise, ID
23 JLUR (soon), Gen 2 Cummins, 22 Sport Alt. R.I.P
I went the cheap rout myself but couldn't find anything that fit the Rubi rock rails or the taller fenders. If you're up for some cutting and running a couple screws into the fenders the Quadratec flaps are working well for me. But as HK1s mentioned, they do exist.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
After hearing rocks constantly 'ping' off my doors, I immediately ordered a set of front standard Rokblokz flaps. Still hear stones occasionally hitting the door, rear fender and side window, but not nearly as many. Seems to be mostly smaller rocks that still sneak by versus everything before. Still kinda wonder if I should've gone with the wider XL flaps, but at the time, I just wasn't crazy about how they looked on stock Rubicon wheels/tires (which I plan on keeping for a while).
Definitely recommending getting something, at least for the fronts and if you're like me and travel through gravel lots or driveways every day, take it slow and easy for the first mile back on paved roads.
Grayhound
Michigan
Jlurd
I went XL and I question if I’d rather have had the smaller ones…
  • Like
Reactions: AFD
Reinen
2021 Jeep Wrangler JL Rubicon
Go with the Rokblox. They'll be there until you do something stupid like not removing them off road and rip them off by wedging them between a rock and your tire. Outside of that they're indestructible.
Willys_Wonka
PA
JLUW
RokBlokz are the way to go. They run in tandem with the OEM rubicon rock rails(pre-cut) or you can get non cut. I also have Ace engineered rails that work with these mud flaps “and” the oem ruby rails, double bonus!
Jeep Wrangler JL Mud flaps? IMG_0651
Jeep Wrangler JL Mud flaps? IMG_0652
Jeep Wrangler JL Mud flaps? IMG_0589
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
I liked the front Rokblokz XLs so much I ordered the rears as well. Good company, easy install, and quality part.
badge171
Frank
central NY
2022 wrangler JLU Rubicon , 1979 CJ 5
Fire Department Deputy Chief Retired
I went with the wethertech thought the look and fitment was much better for my 2022 rubicon , Front and rear !
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
Most times you get what you pay for. Splurge and do as others have said, RokBlokz. They are already set up for a cut out to fit Rubi rails. If you've taken the rails off you just don't cut them. Theres no drilling, they go on quick and are easily removed with a thumb screw when you want to remove them for off road.
Bocephus
Virginia
Sam’s Decorative Automotive Button Emporium
Consider the XR flare extensions, very easy add.
Jeep Wrangler JL Mud flaps? D776D300-90DD-409C-A76A-2AD266293AB8
