Mopar Fox shock length
Napajeep
Vacaville, CA
2019 JLUR
I’ve read the the Fox shocks with the Mopar lift are a little short. For those that have this lift, how close are the shocks to being fully collapsed during full compression (on the bump stops)? Is there enough room that you could put shock extensions on the lower shock mounts to get more droop?
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
They aren’t short. They are exactly what they need to be with a 2-3” lift. If you were so inclined, you could make extensions work with more bump-stop.
Specs for the Mopar FOX 2.5
17.50 collapsed and 26.25 extended on front
19.25 collapsed and 28.50 extended for the rear.
Thanks @AnnDee4444 for the list.
Jeep Wrangler JL Mopar Fox shock length 89F46E67-6994-4DA6-9A53-FDE90A3B3BFA
OnlyOne
Edited
Napajeep
Vacaville, CA
2019 JLUR
Thanks for the response. I was going off of what I had read, and figured if additional bump stops were needed for 37’s (not using all of the up travel on the shock), then why not add extension and regain that lost travel. But if they’re not too short, then all is good. Thanks again.
AnnDee4444
'18 JLR 2.0
FWIW: Due to the angle of the rear shocks, the rear suspension travel is greater than the shock travel. For the Mopar Lift Fox shocks, the suspension could have up to about 10.5" of travel even though the shock's stroke is only 9.25".
AnnDee4444
'18 JLR 2.0
I know the extended length if that helps, 29.3 “‘ in front and 30.3” in rear. I think the travel is 11.5 in front and 12 in the rear , but not positive. The extended lengths I’m sure of.
Are you sure they aren't 28.3125" in the front? I can't seem to find any 29.3" extended shocks listed on their website. From: http://rockkrawler.com/2-25-loop-loop-emulsion-shock/
