MC diff cover
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hello. Anyone install a front diff cover/protector from metalcloac ?
With the gold zinc coating ?
photos ?
Thanks
GavinH
Gavin
JLUR
I’ve got the @Metalcloak skid but not the cover. There’s a version you keep your oem cover
Was any drilling required? Can’t tell how the bolts near the pinion go in I don’t have any holes there on mine.
svc707
Steven
Vacaville,ca
23 JLR, 21 JTM, '23 4RNR
yes, one hole where its flat. once its all bolted up it was fairly easy to drill with skid in place. Ill take a picture when i get home
GavinH
Gavin
JLUR
Appreciate it, why not just use something like a ubolt I wonder.
jhackathorne
Denver
'21 JLUR
IIRC, the best protection is with it bolted to the diff. The way the diff is designed doesn't really allow for a U-bolt type on the front. I am running the diff cover/skid as well and it's help up great. I'd have just kept the stock diff, but they did not offer the diff skid only at the time. Been running it for a year and has some wear and tear and no issues at all.
GavinH
Gavin
JLUR
There’s no drain plug cutout correct? I just don’t know how I feel about the gold but there’s not too many black options out there and I do have other MC products it’d match.
jhackathorne
Denver
'21 JLUR
I have a 21' model so my drain is on the bottom of the diff actually. Just need to remove skid plate to drain mine. I did paint mine. It has some chips in it from road debris and boulders and you can see tiny bits of the gold underneath, but only if you get down under the Jeep and look.
AC77
AC77
AC Abegian
Los Angeles
Jeep Wrangler JL MC diff cover 1698958916477
Bleda2002
2021 JTR, 2021 Sahara 4xe
Scuff it, clean it, etch prime and paint it then.
C.Sco
2023 4xe Rubicon
I just installed the same one last weekend, it's a great product. Went on very easily, only took maybe a half hour. All you really need is an assortment of sockets/wrenches, and a drill with a 3/8" bit, and a couple smaller bits to drill pilot holes so you're not doing all 3/8" at once.
I also own the version that comes with the MC diff cover, it's been sitting in a box for the last 9 months because I never found the time to change the diff cover over. This one for the OEM diff cover is a great solution for lazy people like me.
Jeep Wrangler JL MC diff cover 2023-10-29 10.51.30
AC77
AC77
AC Abegian
Los Angeles
question, what does the Reaper cover for ? engine ?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Make sure you select the right option for your diff now that they have the non drain plug option.
Jeep Wrangler JL MC diff cover IMG_5088
