AVGeek99
- Chris
- Aug 24, 2021
- Peyton, CO
- 2025 JLUR '41, 2024 Rubicon 4xe (wife's) Bright White
- Build Thread
- Link
Your issues sound a lot like mine. Very occasionally (once or twice every couple months) it will get locked in 1st or Rev and creep with the clutch pedal fully depressed. Difficutly getting it in 1st or Rev is more common, almost daily occurence. But it does come and go as well.I'm thinking it holds pressure since the system is "static"? but once you actually start actuating it (driving), it leaks air back in somehow? idk trying to think of something
in my case my clutch was having the same issues, it even creeped when it's locked in 1st or reverse with the pedal fully depressed
BUT it started working fine for like the past 2 months or so with the eventual every once in a while hard to shift into 1st or reverse but it was just "harder" as I was always able to either push it or "wiggle" it in
now I started noticing the same symptoms a little more often again SMH
I saw the photos of the guy who replaced his act with the south bend and the pictures of the act didn't give me any hope for mine
I've never had any pedal feel issues and the clutch engages pretty consistently in the same spot a few inches up from the floor.
Lately, as I've been following this thread, I've been more deliberate about putting it in 2nd (sometimes 4th if 2nd is being a pain) and then it slides right into first. I've also been shifting a little slower as I'm accelerating, which seems to help. Though the 3rd and 5th quite often seem blocked at first, but I release the pressure and retry then it slides right in. 2nd is occasionally difficult when I'm not moving, 4th and 6th never give me any issues.
