Lift question.
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
That's basically no weight. Something is screwed up with your suspension.
It'll beat the crap out of you on and off road. Those springs are intended for rigs that are loaded down with overlanding gear. Consider AEV's 2.5" springs instead.
Mine has steel bumper, 35 and gear, on a 2 door. It sagged in the back on Mopar 2: lift. the front was noticeably elevated. The 3.5 rock Krawlers leveled it out
Jeep Wrangler JL Lift question. IMG_5073
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
That says a lot about the quality of the Mopar lift.
MattyAces
Matty
New Jersey
2021 JLU Willys
I'm just going to say it...friends don't let friends drink and drive or buy rough country.
RC is pure crap. Remove it all and install a quality suspension instead. Do not keep any of the RC stuff. it's all crap.
That's the plan unfortunately it's going to be one thing at a time......stuff seems way more expensive than it usta be 15 years ago when I had my last jeep!
ScotM
Scot
Southern California
The only thing left from the origional lift are the front springs and fox shocks. I upgraded the control arms and sway bar links as time went on. It always sat a bit off from day one. in hindsight , I should have gone a different route
MattyAces
Matty
New Jersey
2021 JLU Willys
The amount of suspension droop is what creates the need for an aftermarket front drive shaft, not so much the ride height. If your front shocks have an extended length greater than 27" you need an aftermarket front drive shaft to prevent the joint at the transfer case end from getting too bunched up at full droop.
Thank you!
Zandcwhite
Zach
Patterson, ca
2019 jlur
Thanks! If I go up to 3.5 inch springs will I need a smaller diameter front driveshaft?
It's not lift height, it's front shock extended length. So long as they are<29" extended the front driveshaft is fine on my experience.
Westymike
bio.site
2021 JLR 2.0 8spd Auto
Digital Marketing / Brand Manager
I run a beefier spring in the rear with a Metalcloak 3.5" lift (overland build) so that I can regularly add 300-400 lbs of gear and not have sag. Here's a pic fully loaded for a week-long overland trip.
Jeep Wrangler JL Lift question. DSC07001
txj2go
DFW
You could just install 1/2" to 1" spring spacers in the back.
