Lift Kit Help
Enlightened_One
San Antonio
2022 JLU Rubicon
Hey brother and sister Jeepers! I have a 2022 Rubicon. I'm sitting on 37's NRG's with a 2'5" Clayton lift kit. I'd like to sit higher; feel like its too low for 37's. What do yall think? Whats the highest I can go without getting to crazy? I was thinking 6" lift, but maybe a 4'5" will suffice. Will I have to do anything else if I go higher? Please share recomendations for lift height, and brand of lift I can consider! Thanks everyone!
Jeep Wrangler JL Lift Kit Help Jeep sid
Jeep Wrangler JL Lift Kit Help Jeep side 2
Jeep Wrangler JL Lift Kit Help Jeep front corner
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
If you're planning keeping the OEM fenders, I feel like a 3.5" lift is enough height while not looking overly goofy. My wifes JLUR has a 3.5 MC GC with a 37" KM3. Lots of room for flex and no rubbing at full articulation.
You can change the inner liners of the fenders to open on the wheel wells, or swap the fenders altogether to get more room.
Roky
Roky
No need to go that high on the JL. You bring a lot of geometry correction into play at 4.5-6”’of lift…..My recommendation is to clearance the fenders, either by chopping oem fenders, or aftermarket……… I’m on 3.5” lift and 37s with fender chop……….
Jeep Wrangler JL Lift Kit Help 8B0D4A2E-466E-42CD-BA43-78910954A53E
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I had the 3.5" Metalcloak Gamechanger that gave an actual 4" of added height after the added weight of armor, winch, and other accessories. I also had the 38x13.5 Patagonias on 17x9 wheels.
At that tire size, it's best to buy once cry once. To build a solid and proper base it's best to go with a lift that upgrades all 8 control arms and both track bars, along with a set of stronger steering linkages.
Jeep Wrangler JL Lift Kit Help 20211013_132632
hoag4147
Colleyville, TX
2022 JLUR XR
Love seeing pics
hoag4147
Colleyville, TX
2022 JLUR XR
Always like seeing pics with 38s and now the 40s ??
Carlton
Chicago
Jeeps lots of jeeps
If you plan on sticking with 37s keep itbas is. With 6" of lift you could be on 42s...
I had 40's on a 4" kit.
Jeep Wrangler JL Lift Kit Help 20190713_124402
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
I think a 3.5 looks just right with those tires. I recommend the Metalcloak 3.5 Gamechanger. They tend to run a little high so you could end up over that 3.5.
Headbarcode
LI, New York
I originally netted about 4.5" with the 3.5" Gamechanger. It dropped to about 4" after adding the winch and mounting plate, lighting and their controllers, sliders, air compressor, stronger rear bumper, and hinged tailgate reinforcement.
Jhawth
Jake
Minnesota
2021 JLUR
Are you wanting to wheel this jeep or keep it on pavement?
If you're planning on wheeling it, keeping it as low as possible and getting the most articulation out of it as possible is the more ideal solution.
Once you get it too tall you decrease the amount of roll the Jeep can handle before... it rolls over.
37s on 17" beadlocks and a 3.5" MC GC lift:
Jeep Wrangler JL Lift Kit Help 20220515_093517
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Of course you can go with a six inch lift. Sounds like you're going for a "look" and not performance, so six inches sounds about right. I'm not sure if there are taller lifts available, but since you're already running a Clayton lift, you might try their 3.5" and then use some 2" spacers on top. I know that doesn't get you to 6", but you could then use a 1" body lift. The body lift doesn't raise your center of gravity as much as a spring lift, but that should be ok since you don't care about performance.
COJeeper
Severance, CO
'22 JLUR, '23 Donkey because gas is too expensive
I vote you go 6" lift and sell me that Clayton lift for cheap. :like::jk:?
My 37s should be coming this week!
JLUHT
Nebraska
'22 JLUHT (JLHT?) '19 F-150 5.0 '03 Envoy XL
RE20 microphones
Bump the springs up to the 3.5" Clayton's?
