Leaking AEV RT5100 shocks
wwtucson
William
Thousand Oaks
2023 jeep wrangler Rubicon
The rear shocks ( RT5100) on my AEV lifted and equipped shock are Leaking oil. They only have 19K miles on them.
Can they be rebuilt?
Jeep Wrangler JL Leaking AEV RT5100 shocks 20260615_080027
Jeep Wrangler JL Leaking AEV RT5100 shocks 20260615_075839
jadmt
jeff
montana
no you can not rebuild 5100's contact AEV and they should warranty them. Bilsteins have life time an AEV has a lifetime warranty if you are the original owner with proof of purchase. this is the number to call. 248-926-0256
wwtucson
wwtucson
William
Thousand Oaks
Thanks !
Panhead5
Bob
Columbus, Ohio
2024 Jeep JL Wrangler Rubicon 2024 JL wrangler Rubicon xtreme
Grease monkey
Good luck with that . I have 2 leaking AEV Bilstein shocks and had to buy both of them from AEV.
wwtucson
wwtucson
William
Thousand Oaks
I hope that's not the case. The thing that got me looking under the back end was the left rear tire to fender clearance was three inches more than the right. I first thought I may have a busted spring. Now think something inside the shock is holding it up.
jadmt
jeff
montana
a shock even if completely blown is not going to make 3" of height difference. you have something else going on.
jadmt
jeff
montana
bring them with you and you can take them to Dave in person..
Gorpf
‘21-392, AEV-JL370
Retired/Caregiver
I wouldn’t count on AEV covering anything under warranty. I’ve had several small parts of theirs fail and was made to purchase replacements each time(under 10k miles). Most recently the threads at the adjustment bolt on the turnbuckle for their spare tire mount stripped while on the trail.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
They replaced a leaking steering stabilizer on mine. Ditto for 4.63 rear diff gears a few times, eventually replacing rears and fronts with 4.56s.
wwtucson
wwtucson
William
Thousand Oaks
Update.
AEV has contacted me two times looking into the issue. Great customer service.
Panhead5
Bob
Columbus, Ohio
Grease monkey
You guys must have connections
