txj2go
Carry an adjustable wrench with you so you can disconnect the negative cable for the small battery and then use the jump pack. From reading some threads here I wonder if the small battery isn't normally the problem anyway. The one caveat is that you have to have a 2019 or later or a flashed 2018, or an appropriate jumper to use in the fuse block.@Levin_tom
and can separate out the two batteries, that you will not be able to jump pack start a 3.6 whose 2 batteries are depleted..
