Jumping your Jeep..... who has done it with a battery pack?
  1. Dkretden
    Dkretden Well-Known Member
    First Name:
    Vehicle(s):
    2020 JLUR 3.6L
    Jan 29, 2019
    Houston, Texas
    1,089
    Liked:
    932
    #1 Feb 16, 2020
    I am aware that ONE poster— @Blu bi Kong —- here has used a JNC 660 battery pack to jump his Jeep. Has anyone else been successful using a battery pack to jump his/her Jeep and, if so, which brand/model jumper pack? And, which engine? 3.6L or 2.0T BSG?
  2. jeepster345
    jeepster345 Well-Known Member
    First Name:
    Hunter
    Vehicle(s):
    2018 Jeep JLU
    May 25, 2018
    Miami
    95
    Liked:
    81
    I've used the NOCO GB40 with no issues. :)
    Dkretden likes this.
  3. OP
    Dkretden
    First Name:
    Vehicle(s):
    2020 JLUR 3.6L
    Jan 29, 2019
    Houston, Texas
    1,089
    Liked:
    932
    3.6 or 2.0T?
  4. Rploaded
    Rploaded Well-Known Member
    Vehicle(s):
    2019 JLUR
    Dec 30, 2018
    Houston
    535
    Liked:
    638
    Noco Boost HD GB 150
    Works fine for what I’ve thrown at it.
  5. OP
    Dkretden
    First Name:
    Vehicle(s):
    2020 JLUR 3.6L
    Jan 29, 2019
    Houston, Texas
    1,089
    Liked:
    932
    It would seem that one could power a small city with that thing!
    ‘thanks!
  6. HamiltonGuy
    HamiltonGuy Well-Known Member
    First Name:
    Dino
    Vehicle(s):
    JLSU
    Jun 16, 2018
    Guelph
    73
    Liked:
    70
    Is the boost immediate, or do you leave the battery pack connected to charge up the aux battery or something like that? I read somewhere it isn't just a matter of connect and start it up.
  7. Rploaded
    Vehicle(s):
    2019 JLUR
    Dec 30, 2018
    Houston
    535
    Liked:
    638
    When it comes to recovery gear and safety stuff, I always figure go with best you can afford and or reasonably carry. Yeah it holds a decent amount of power but if I’m in the wilderness and need to hike I’ll take all the portable power I can for phone and ham.
  8. OP
    Dkretden
    First Name:
    Vehicle(s):
    2020 JLUR 3.6L
    Jan 29, 2019
    Houston, Texas
    1,089
    Liked:
    932
    Dino, while your question is important, I am trying to focus this thread on the actual jumper itself. It looks, so far, that 3 will work:
    JNC 660, with 1700amps
    NOCO GB640 with 1000 amps
    And
    NOCO GB150 with 4000 amps
    others?
  9. Compression-Ignition
    Compression-Ignition Well-Known Member
    First Name:
    Roy
    Vehicle(s):
    2020 JLUR 3.0 Diesel (FIRECRACKER RED), '11 QX56, '05 5.9 Cummins
    Nov 12, 2019
    Eastern Washington
    247
    Liked:
    281
    I think you want to leave it connected for a bit.
  10. Rploaded
    Vehicle(s):
    2019 JLUR
    Dec 30, 2018
    Houston
    535
    Liked:
    638
    This depends on your setup. The 3.6 AUX battery is a POS and costly to repair and frequently fails; if I had it I would be switching to a dual battery setup.
    The 2.0 E-torque you just fire and go, no waiting etc. The 48v battery is waiting patiently to charge the 12v. All you need is to get the motor started and it will handle the rest via control modules.
    The 2020+ 2.0 non BSG I would also get a dual battery setup as I think it’s got the same POS Aux battery the 3.6 received.
  11. fat_head
    fat_head Well-Known Member
    Vehicle(s):
    2018 JLU
    Mar 28, 2018
    578
    Liked:
    986
    You’ve jumped a 3.6l JL with it?
  12. roaniecowpony
    roaniecowpony Well-Known Member
    Vehicle(s):
    JLUR, 14 GMC 1500 CC All TERRAIN
    Dec 4, 2018
    90505
    1,291
    Liked:
    1,087
    Occupation:
    Retired Engineer
    I jumped my JLUR with a cheap Costco pack. Hooked it up and immediately started it. The vehicle doesn't know which brand it is. All that matters is how much capacity the battery in the jump pack has and how big the cables are.
    rumblejeep likes this.
  13. OP
    Dkretden
    First Name:
    Vehicle(s):
    2020 JLUR 3.6L
    Jan 29, 2019
    Houston, Texas
    1,089
    Liked:
    932
    Do you know the specs, by chance, of the Costco pack?
    and, 3.6 or 2.0T BSG?
  14. Gee-pah
    Gee-pah Well-Known Member
    First Name:
    Andy
    Vehicle(s):
    JL Wrangler
    Nov 19, 2019
    SanFrancisco
    413
    Liked:
    266
    ...and, I'd imagine, how much power is in the battery/batteries (3.6L there's two) even if they lack adequate power to crank the engine
  15. Gee-pah
    First Name:
    Andy
    Vehicle(s):
    JL Wrangler
    Nov 19, 2019
    SanFrancisco
    413
    Liked:
    266
    To build upon @Rploaded's response Dino, the answer to this question is likely to be determined by which JL you have (e.g. 3.6L or 2.0L) and how you hook up the jumper cables.
    Take the 3.6L. The owner's manual calls for you to sit with energized jumper cables for a while on the main battery's posts. This is for the purposes, more than anything else, of charging the ESS/Aux battery, which is connected in parallel to the main battery when the 3.6's at rest. Yes, you are charging the main battery too here, but it's really that ESS/Aux battery that much have a threshold of power or the 3.6L won't even attempt the crank.
    Yes--that crank is powered by both batteries, (If available--see below) but it won't even be attempted if the ESS/Aux battery, tested in isolation first by the 3.6L, shows as lacking a certain threshold of power. Funny enough, with both batteries topped off you could crank and run your 3.6L on the ESS battery alone, but not the main battery alone. It's a long story as to why, and I can link video demonstrating this if you wish.
    It's funny how you mention how long to wait. I debated here (with our resident expert @Jebiruph) hooking up a power pack to the positive post of the main battery, and the temporarily disconnected cables normally connected to the main battery's negative post, all while jumpering, with a fuse, terminals N1 and N2 in the Power Distribution Center.
    https://www.jlwranglerforums.com/fo...-any-jumpstart-tips.12316/page-11#post-986785
    That's a mouthful if your not already acquainted with this stuff. The idea was to hook up in parallel to only the ESS battery and immediately crank, not wasting precious jumper pack power on charging a main battery that once the rig is cranked, the alternator will charge.
    Rploaded likes this.
Loading...
Share This Page
