Jumperless Aux Battery Bypass
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Are all of your Service Bulletins and recalls up to date? I thought there was an update that would allow the Jeep to start with a weak or dead Aux battery. Maybe this is your scenario and the Aux battery is weak?
Possibly? I only have the 7 inch screen and it looks like the parasitic draw issues were with the 8.4 screen. Not sure which other ones could affect it, or which ones you’re referring to, but should mostly be up to date.
Jebiruph
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
It was strange for sure. I’ll try it one more time later, but it was definitely weird. Thanks again for all the work you’ve done on this topic. Read about 25 pages of the original thread on this then found this simpler way of achieving it.
I just found the simpler way of doing it a couple weeks ago. :)
rhocking
IL
2020 Wrangler 2.0T JLU Sport S
Is this simpler way just for 3.6L or does the fuse pull and battery disconnect work the same on the 2.0T?
Is it the same fuse?
Omen
Wisconsin
2022 JL Willys 2.0
IT Manager
I have a 2022 JL 2.0t and I just had to do this today as a result of dead batteries when I tried to go to work. I drove back and forth to the dealer after making the change (10 miles round trip) and everything behaved as expected - no EVIC errrors. The ESS still functioned off the main battery, but after it reminded me that it was on, I shut it off.
Omen
*edited for some spelling errors.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
Did this w/ my '21 JLUSS 3.6L/6 speed manual last night. Same fuse, same location, no issues. I'll pull the fuse and remove the jumper on the wife's '20 JLUSS 2.0L/850RE tonight, but I don't expect any issues there either.
--EDIT--
As expected, no issue w/ the same mod if you have the 2.0L. Been flawless on my wife's 2.0L JL as well.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
On a 2019 the aux battery ground connection should definitely be the one that’s easier to remove correct? The smaller ground connection? Just want to make sure I didn’t remove the wrong ground. Thanks.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Yes it is the smaller ground that is in the post.
Dewey7015
Cape cod
2020 JL 2 door, hardtop, 6 speed.
This..... Is absolutely awesome.
I have a 2020 jl sport. Never used the ESS, because I have a manual trans, so I keep it in gear at red lights.
Pulled the fuse, taped the aux ground back, and it works like a charm! Thanks for doing the research!
correfe
Fernando
Toronto
2018 JEEP JL SAHARA UNLIMITED
While working on another project, I was looking at the fuse descriptions on the underside of the PDC cover and saw this - F42 PCR CTRL FEED (ESS)*. Could it really be this easy? Yes it is. I pulled the fuse, disconnected the aux negative cable from the main battery negative post and it started right up without any errors.
Unplugging the PCR has always been an alternative to using an N1 N2 fused jumper, both methods defeat the aux battery pass/fail test that occurs prior to a cold start. Unlike using a jumper, unplugging the PCR doesn't require any additional parts, it's just not easy to get to the PCR plug. Removing the F42 fuse accomplishes the same thing as unplugging the PCR and the fuse is easy to get to.
Other than a couple starts, I haven't had the chance for real world testing, but I did look at the schematic and verified that pulling the fuse accomplishes the same thing as unplugging the PCR, both prevent the relay from activating.
Here's the underside of the PDC cover showing the description and location of the fuse.
Here's the fuse location with the fuse removed.
Here's the schematic showing the fuse in the circuit.
Thank you for this update on the AUX / JUMPER / PCR.
I have been with the "avengers light" for a while now, not wanting to unplug the PCR or Jumping the posts.
I have just pulled this fuse as well, cleared the codes to clear the light, and it works like a charm.
Now i just have to remember to press the ESS button, to turn that stupid start/ stop function every time I start the Jeep.
vmdirt
Todd
STL
2019 JLUR
Funny little story... I picked up a 2019 JLUR a couple of months back with only 8k miles on it. Spotless. Even had the bonus of a WARN winch already installed. This is my first Jeep and as I got to reading about it I found out about the dual batteries and that the smaller one seems to only be good for 2 or 3 years. It seemed to me that would not be a great situation for the main battery if they were in parallel. I also had visions of this thing going bad during our 3 week trip out West coming up soon. So the more I researched about removing that smaller battery I came to this thread last night and thought, "genius. I can easily delete this battery".
I figured I would get my meter out and check the condition of each battery individually just for kicks but still planned on just deleting the smaller battery. I opened the hood and checked the fuses and noticed F42 was already removed. Then I noticed the negative cable from the winch was connected to the main battery where the ESS battery would normally connect. Then I noticed N3 had no cable connected to it. Voila! Battery delete was already done! :) I assume whoever put the winch in might have done the battery delete as well. Thanks for the thread anyway. It must have come in handy for the people who owned this thing before me. :)
EDIT: I just noticed this thread was started after I bought my Jeep so someone else must have figured out the same thing. I can't find any similar battery delete threads mentioning the fuse so thanks anyway for this thread. It seems like the best way to do the ESS battery delete.
Jebiruph
Jebiruph
Jerry
Iowa
Is your's an eTorque engine instead of an ESS engine?
vmdirt
Todd
STL
2019 JLUR
Ahhh, maybe that's it. The Mopar site shows this for my VIN: 2.0L I4 DOHC DI Turbo eTorque Engine
Those don't have the 2nd battery? I guess I need to do more research before posting cute messages on the Internet. :)
EDIT: I checked, and not only did they remove the little battery from the engine compartment but they installed a big battery under the belly! :) I can't believe this didn't cross my radar. :) I thought there was only a 2.0, a 4xE, a 6 cylinder, a diesel, and a V8. Didn't realize there were multiple versions of a couple of them.
mdkautzman
Centralia, WA
2021 Jeep Gladiator
Thanks for pushing though on this. Oddly, my aux negative disconnect and main battery ground seem to be the opposite of what's shown in the videos in the other ESS disable post. Thinking I might have missed a twist in the pairing without pulling everything out, I followed the instructions anyway for pulling that lead off after pulling the fuse and had no power to the Jeep. Do the techs actually have to clamp the terminal connectors on and did so in reverse or did they just attach them incorrectly? It just seems odd that the larger anchor blade terminal is attached to the smaller wire for the aux negative lead.
Edit: Pulled both leads off and reconnected the larger ground wire back. Works as described above. Pics added for reference.
My 2029 JT was even different from both. For all just find the smaller cable we're ever it is and leave the larger. Thanks OP!
mdkautzman
Centralia, WA
2021 Jeep Gladiator
Here's my JL negative cables. Changed again! The aux battery is the flat with post that's attached with small bolt. I will need to swap to a longer bolt to add my winch and compressor ground to.
There on to us and making it harder that just removing a wire. Damn them!
My JT was just opposite.
Jeep Wrangler JL Jumperless Aux Battery Bypass PXL_20220809_011110775
