rcadden
- Ricky
- May 4, 2021
- Asheville, NC
- 2021 Hydro Blue Sahara Altitude
- Build Thread
- Link
- Occupation
- Marketing
So I have a Sahara Altitude. Came from the factory with 32" Duratracs. Swapped with 33" KO2 Rubicon takeoffs back in December. Have had 2 oil changes since then, at the dealership (cause free).
Finally had some change to get an adapter and whatnot and got all kitted up with JScan, so I could tell the Jeep it's turning 33s instead of 32s.
Get it all hooked up, etc, no problem. Measure my tires as JScan recommends, ground to top of tire. 31.5" on the nose (seems low, but I do run at 35psi)
I load up JScan and it says my tire size is already set to 32.25".
So....not real sure here.
1) Would the factory have set it to 32.25" instead of actually measuring the tire?
2) If not, then is it possible that one of the two dealerships hooked into the OBDII while doing my oil change, noticed the tires didn't match the system, and updated it "for me" (without mentioning it)?
3) If my system reads 32.25", but my tires measure 31.5", which should I program to have things setup most accurately?
