Jscan functionalities
Cartman
ANDREW
Slovakia
Jeep JL Sport+ 2d 2023
I really miss some thread about JSCAN functionalities.
I have so far done this via jscan:
- turned off sirius - unavailable in EU
- switched the radio to European frequencies
- switched the daytime running lights
- turned off the seat belt warning light
- managed to turn on the remote start
I have not yet managed to:
- turn off the three beeps when leaving the car with the key in hand
And I have a question for more experienced users. Is there a control unit or something in Jscan where I can see the response of the 6 multimedia buttons on the steering wheel? The other buttons work for me, but the multimedia one hasn't for over a year. I imagine something like that where I can see the response of the buttons on the steering wheel after pressing.
So far I've taken the steering wheel apart, completely checked the buttons, wiring, and radio connection
(28) Steering wheel audio controls malfunction | Jeep Wrangler Forums (JL / JLU) -- Rubicon, 4xe, 392, Sahara, Sport - JLwranglerforums.com
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Why was remote start disabled? JScan cannot remove the 3 beeps. Tazer might be able to or not, unsure.
JScan has live functions but I am pretty sure it doesnt have what you are looking for.The creator is very active on Facebook, in the group "JScan Lovers", ask in there maybe.
Cartman
Cartman
ANDREW
Slovakia
My Jeep do not have the remote start from factory.
I will try facebook group. Thanks
Cartman
Cartman
ANDREW
Slovakia
You have to anable it to make it work.
Spacenut
Michael
Michigan
2018 Wrangler Rubicon 2 Door
I turned off the tpms system on my 2018 because jeep changed the sensors at some point. I installed 2024 wheels and tires to find this out.
Cartman
Cartman
ANDREW
Slovakia
Try MODULES -> Body Controller -> LIVE DATA ->
Steering wheel switch 1
Steering wheel switch 16
Nothing could be seen there... :(((
Cartman
Cartman
ANDREW
Slovakia
I preaset all buttons multiple times. And only one time arrow up seems to produce visible.trace in log. Maby I use it wrong. All buttona except 6 audio buttons worka correctly.
THAW
Foster
23 JL4DrRubicon
I tested it, and discovered the buttons must be held down due to JScan/OBD-II polling speed. If the button isn't in the pressed state while the little arrow in JScan indicates the individual PID updating, the pressed state won't register.
If I remember correctly, the audio buttons (on the back of the steering wheel) were numbered, from top to bottom: left-side -> 4, 9, 5; right-side -> 1, 3, 2.
