JSCAN
Cartman
ANDREW
Slovakia
Jeep JL Sport+ 2d 2023
guys, am I able to turn off brake after open the driver door? I want to fine tune my ride with opened driver dooer, but car allways stops.
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
@Terrymo
@THAW
@others
Yes, JScan maintains a list of supported adapters but not all adapters on the supported list are lets say created equal. Some do the job but can't handle all that JSCAN can throw at them. Some do their deed more slowly then others..
Last time I had a FB messenger back and forth with the guy in Poland named "Piotr Bialic" who brings us JSCAN, he talked very highly of both the Vgate VLinker MC+ and the OBD Link MX+ .
He said both, unlike some adapters could handle all that JSCAN threw at them and in a timely, non-problematic manner.
With that said, I always tell JL/JT guys/gals to go with either or.... either a Vgate VLinker MC+ or the OBD Link MX+ . I do though lean heavily toward going with the firmware up-gradable OBD Link MX+ . Jason from OBD Link is a forum member here is quite on top of things lets say... and he is known to communicate with JSCAN to assure the OBD Link MX+ iis on top of things JSCAN wise..
Read here:
https://www.jlwranglerforums.com/forum/threads/✅-important❗-update-your-bluetooth-obd2-scanner-✔firmware-updates.97511/
Great info and I just bought the OBD Link MX+, Z Automotive Mini Tazer and Z Auto SGW bypass harness, trying to learn how to plug it all together and use them together in a beneficial manner.
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
Unplug the wire harness for the door and the jeep won't know the door is open.
Better yet. Take the door off.
Cartman
ANDREW
Slovakia
Not in winter....
Terrymo
Terry
2023 JLURXR 3.6 ET
Do you mean with the engine running, the Jeep in park, parking brake on, and the keys in the center console, the engine stops running if you get out?
Or do you mean running, in park, parking brake off?
I guess I need to try this.
I don’t leave the Jeep running while working on it without the parking brake on.
THAW
Foster
23 JL4DrRubicon
I believe he's referring to Auto Park.
@Cartman, if so, the easiest way to disable it is leaving the driver's seat belt fastened
Cartman
ANDREW
Slovakia
Ok if its called auto park ok. Is there any harder way? To turn it off?
