NCJeepn73
- Jul 3, 2018
- North Carolina
- 2018 Jeep Rubicon JLU, Bld date: 2/2018
- Occupation
- Technical SEO & Web Development
I've never seen frame welds mutilated in this way and then given it back with a "here you go. everything should be fine now" reply. My main welder contact already checked the re-welds and said they basically just ruined brackets and welds. He also mentioned what you did -- that to do it right the welds should have been taken all the way to the bracket lips, disconnected, all areas cleaned appropriately, then re-welded. It just looks like really bad lipstick on a turd at this point.Yikes. I would not accept those. Its just masking the problem cosmetically. You cannot put a weld over a porous weld...especially one that has slag on it. The only way to really make sure the new welds are good is to completely ground down the weld and put a new one in. Further you'd want to use either a frame jig or at minimum a bunch of clamps to keep it from moving. What they did to yours is unacceptable.
