JL Tazer Mini - TPMS Threshold
AZDIESELRUBI
Shawn
Tucson
2023 JLU Rubicon
So I can not remember if the TPMS light was disabled when in 4LO so I figured I would set the TPMS threshold on my JLU to 15 PSI - after all I saw that "other" guy on that "other" Jeep forum set his TPMS to 15psi on his JL. - His video was from 2018 -
I could not get mine to go below 25psi. Was this changed in later versions of the Tazer for the JL? Tomorrow is the maiden wheeling trip in the JL so I am guessing I will have a TPMS light after airing down?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
25psi is as low as you can go...
From what I understand, FCA has set the minimum to 25psi . Undoubtedly, the 25 psi must be mandated by the law.
I know Joe at ZAutomotive has tried multiple times, to work around this 25 psi thing, but has been unable to do anything about it. It's been a no go with JSCAN also.
You could turn off TPMS readouts, altogether..
AZDIESELRUBI
AZDIESELRUBI
Shawn
Tucson
2023 JLU Rubicon
I
Looks like I will have turn off the light.
It should be something that happens when in 4 lo!!
Rhinebeck01
Retired at 55 ..
I
By the way, from what I read in another thread, you are incorrectly using your security gateway extension cable.
AZDIESELRUBI
AZDIESELRUBI
Shawn
Tucson
2023 JLU Rubicon
What do you mean? Doesn't it plug in to your gateway then in to the factory plugs so you do t have reach under the dash and kill your back when you need to plug in the Tazer?
How else would you use it?
Rhinebeck01
Retired at 55 ..
You said this in another thread "On the other side I had no issues connecting the Tazer Mini to the extension cable."
Tazer JL does not plug into the security gateway extension cable....
Do read here ....
https://www.jlwranglerforums.com/forum/threads/➿-security-gateway-extension-cable-use-explained-➿.111159/
AZDIESELRUBI
AZDIESELRUBI
Shawn
Tucson
2023 JLU Rubicon
