Jl manual owners
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Soooo after viewing these threads I’m actually contemplating backing out of my ā€˜25 manual JL order.
it just doesn’t seem worth the hassle and the headache.
is it really that bad with the new manual JLs?
Some people have great luck with manuals. Others (like me), not so much. We speculate that the quality control on them is worse than usual since people have driven multiple new manual JLs and realized that they each can behave significantly differently.
GabeBoyTheGreat
Virginia
2018 JL Sport, 2025 JLU Willys
Test Engineer
Thank you for taking the time to record that! That seems like it. I can’t imagine having that and leaving the auto start-stop on. I just wanted to make sure it’s normal for the Wrangler and not causing damage from something being unbalanced.
Not a problem at all. That is what the forum is for, right?
I just wanted to understand what exactly you are talking about. This occurs on both my 2018 and 2025, so yea, I would say it is normal and not to worry about it. I am a little bit surprised you noticed because the "shudder" is so subtle that I hardly notice it at all; I thought you were describing something much more violent. Interestingly, this vibration is much less noticeable on my manual Camaro SS, so it does appear to be a characteristic of the Jeep.
However, it makes total sense that you wanted to check to see if it was normal, as abnormal sounds/vibrations could be a sign that something is wrong, so I understand why you wanted to check into it.
By the way, from the sounds of it, most people disable ESS anyway due to its annoyance and lack of real-world benefits. Even when I do seldom use ESS, this vibration doesn't bother me at all; I just attribute it to normal vibration when any engine shuts off, even if other cars don't do it.
Honestly, if this behavior is making you consider backing out of your order, I recommend not buying a Wrangler at all. This vibration/shudder goes completely unnoticed in my day-to-day use of either Wrangler; there are MUCH greater vibrations/noises just driving pretty much any vehicle down the highway, let alone a Wrangler. If this minor vibration bothers you, you will HATE driving the Wrangler.
That being said, I recommend just hopping in a manual Wrangler at the dealership and just test out the vibration for yourself. That is the only way to know for sure.
Again, I think we are making a mountain out of a mole hill here. There is nothing wrong with this behavior. OP just wanted reassurance that nothing was wrong with his particular Wrangler because he wasn't used to it.
MichLS1
Michigan
JL
I would recommend taking one for a long test drive.
HydroBlueTexasStar
lee
Dallas, Texas
ā€˜25 Hydro Electric Blue 2-Door JL
nah I wasn’t saying just this thread. There’s been a couple but from what I’ve heard from the dealer, the new JLs being built have a new transmission from the earlier models so I’m hoping I get lucky.
Mothman
WV
2020 JL 2 Door
2020 JL and no
also agree this is the wonkiest clutch ever
how I yearn for a mechanical lever clutch like in the old days
coupedncal
CoupednCal
SF Bay Area
2024 JLUR
No issues with a 2024 manual. Not sure why the manual gets such a bad rap. The first gear is tall (or is it short?) but that is it. It works great for most of us.
Jaz Bennett
Jaz
NC
2018 Jeep Wrangler unlimited Rubicon JL
Veteran
Does anyone with a manual get a shutter when they shut it off? Dealership says it’s ā€œnormal for the manual.ā€ By shutter, I mean it visibly shakes when I shut it off. It’s a 24 and it’s done since new. Additionally, what could cause it? Thanks!
I have an 2018 JL that's manual, but mine doesn't shutter when turning it off when I can get it to turn off.
vasdimpop
Vasil
MY25 JLUR (being built)
I’ve had a 21, 22 and a 25; all manuals and none shuttered when turning them off.
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
I’d be willing to bet they do what op was trying to describe if they had the stock clutch and flywheel. He was feeling the dual mass flywheel harmonics
GeorgeYJ2JL
George
Camaro ZL1, M3, Ram 1500, Willys JL
None on my '25 Wrangler 2dr 3.6 with a 6spd, but it does hesitate in 4th gear with any load
Maverick909
I.E.
www.instagram.com
nope
Skytow
JD
SE PA
ā€˜09 JK 6MT, ā€˜21 JL 6MT
2021 JL nope.
