Jl manual owners
MichLS1
Michigan
JL
Does anyone with a manual get a shutter when they shut it off? Dealership says it’s “normal for the manual.” By shutter, I mean it visibly shakes when I shut it off. It’s a 24 and it’s done since new. Additionally, what could cause it? Thanks!
CapeArt
BB
Cape Cod
2023 JL Sport S, Porsche 987S, MazdaSpeed Miata
No
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
Mine makes the rattle noise of a dual mass flywheel when shut off if that’s what you’re referring to.
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
Nope
BUT...it's a bit of a trick to get used to driving the JL Manual. Could be the way you're engaging 1st - just an idea
SadRobot
Los Angeles
2025 Prius LE
Can you post some video of what you are talking about?
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
My 2025 doesn’t do it. But my 2018 civic si did. I changed out the rear motor mount to aluminum with stiffer race bushings and it went away.
MichLS1
Michigan
JL
It just started making that rattle, but the shaking can be felt and seen when I shut since new.
GabeBoyTheGreat
Virginia
2018 JL Sport, 2025 JLU Willys
Test Engineer
Are you saying when the engine is shut off or when you are starting off in 1st gear?
Sardaukar
Wisconsin
2023 JLUR 6MT, 2023 JT Sport S
Software
Nope on 23 JLUR.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
I've been driving my manual for 7 years, this is not normal. I suspect your dealer is giving you their standard answer for whenever anyone complains about a Wrangler. Take someone for a ride and see what they say after that.
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
Athletic trainer & Massage therapist
It’d help if you could post a video, but from what you’ve described — no. I’d say the dealer is blowing smoke and try a different dealer.
