JeeperJC
- James
- Feb 17, 2022
- Merritt Island, FL
- 2022 JLUR and 2020 Jeep Gladiator
I have searched and found threads on JL's not starting or people asking how to install a remote start on a manual, but I wasn't able to find anything related to installing a momentary switch to bypass the clutch interlock so you can start it in gear (any tcase range, not just 4lo) without depressing the clutch (my goal is to have a manual override in the event you need to stop and then start again while in a river crossing as an example).
I've had a clutch bypass switch on most of the manuals I have had over the years (and it used to come from the factory on the old 4runner/taco's). I'm looking to see if anyone has successfully installed a momentary switch to bypass the clutch interlock on the JL? I found the following diagram elsewhere on the forum:
I found the location on the clutch master cylinder between the brake booster and the driver fender, as well as the Green/yellow and black wires. I was looking to confirm if anyone has installed a momentary switch to bridge the connection and if so, does it throw any codes? Do you bridge the two wires together, or do you run a new ground and connect it to the Green/Yellow wire with the switch?
Thanks in advance!
Thanks in advance!
