JL Brake Line Relocation Kit
WVrubicon
Justin
Paw Paw, WV
2021 Wrangler
I did a Mopar 2" lift on my JL but it came out to about 3" in the end. I am worried about the brake lines and have heard there are relocation kits that adjust where the lines are held to the frame but I can't seem to find anything on the net. Has anyone relocated these mounts or did you just add extended lines?
4xFUN
Scottsdale AZ
Rancho makes a nice one that I used, PN RS62136 only cost about $30.
EDIT NOTES: These are for the parking brake lines and the center mounting bolt should be installed from the top of bracket down as shown and not from the bottom up as in Rancho's instructions. This is to avoid any potential rubbing of the bolt on the gas filler neck.
Jeep Wrangler JL JL Brake Line Relocation Kit IMG_1238
Jeep Wrangler JL JL Brake Line Relocation Kit IMG_1239
Spank
I've been running the Mopar 2" lift for three years now and had the same result (3" of lift). I haven't had any issues with my brake lines and I've exercised this kit to its maximum capabilities.
Roky
Roky
I use these ....... best 23.00 I’ve spent...:)
Jeep Wrangler JL JL Brake Line Relocation Kit D1A77C1F-D900-43AC-B7D5-6DB4EFF39917
Jeep Wrangler JL JL Brake Line Relocation Kit 8361A632-B0B0-4FF7-8E4F-8C18771D4245
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
Those are the nicest parking brake cable brackets out of a kit that I've installed. Hands down better than any others.
https://www.northridge4x4.com/part/...rancho-performance-e-brake-relocation-bracket
Jeep Wrangler JL JL Brake Line Relocation Kit Screen Shot 2021-03-10 at 8.01.22 AM
From our Rancho install write-up: http://www.northridgenation.com/rancho-2-lift-kit-for-your-wrangler-jl-install-how-to/
XxsullyxX123
Somers, NY
2020 JLU Rubicon Recon, 2020 Honda Pilot Touring
While the Mopar lift does give more height than advertised, the real factor into what would strain the brake lines would be the “downtravel“ you get when fully flexing the suspension. Same with any wear and tear on the driveshaft. From what I understand, the Fox shocks paired with this lift don’t allow for enough downtravel to cause an issue with the brake lines/driveshaft.
Full disclosure: this is NOT from personal experience, but through my significant reading of these forums as I plan my own build.
WVrubicon
WVrubicon
Justin
Paw Paw, WV
2021 Wrangler
I had the same exact concerns and after reading responses here I ended up purchasing the Teraflex relocation kit. In the end I now have more than enough brake line, didn't have to bleed brakes (huge win), and the kit was super easy to install.
Jeep Wrangler JL JL Brake Line Relocation Kit BrakeLine
JMP
Jason
Little Rock AR
JLUR XR, M2
Pirate
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
What amount of droop (sock length) necessitates these?
Rancho includes those with their 2" lift kits.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
JMP
Jason
Little Rock AR
JLUR XR, M2
Pirate
Stuckinthesand
CJ
NJ
At that length I think you may need a new driveshaft as well. If I recall correctly anything over 28" or 29" will be an issue.
BDinTX
Dallas, Tx
For those that did the new brake line things, how did you pry the original ones from the brake line.
Just "very carefully" or is there more to it?
