JD Powers Survey
Status
Not open for further replies.
John Benoit
Loveland, Ohio
2023 Jeep Wrangler Rubicon Unlimited
After 23 pages of insightful discussion, sharing of knowledge and playful bantering, I am thoroughly convinced that our little Jeep forum has convinced OP (Mssr Benoit) to petition JD Powers for an opportunity to retract his original response so he can proclaim he was mistaken the whole time, set the the record straight and officially declare that JEEP DOES CARE.
Not hardly. Jeep doesn’t care. Why won’t they correct the suspension or transfer case vent.
gek
Code Monkey
It has stock Rubicon springs on it. It has 68540191AB on the front and 68540224AA on the rear. The 1 1/2 inch lift springs are front 68254661AD and or 68253662AD, the rear, 68253591AA and or 68253592AA.
You will notice that all of these springs list other vehicles that are not Rubicons furthering my point that spring selection is based on the options and model and not just the model.
You will notice that 2 door is even listed furthering my point as there is no 2 door XR option.
Spring 1 68254661AD did not show any results so I am showing 68253661AD
https://parts.moparonlineparts.com/search?search_str=68254661AD
https://parts.moparonlineparts.com/oem-parts/mopar-front-coil-spring-68253661ad
Jeep Wrangler JL JD Powers Survey 2023-11-17 11_51_31-Window
Spring 2 68253662AD https://parts.moparonlineparts.com/oem-parts/mopar-front-coil-spring-68253662ad
Jeep Wrangler JL JD Powers Survey 2023-11-17 11_50_28-Window
Spring 3 68253591AA https://parts.moparonlineparts.com/oem-parts/mopar-rear-coil-spring-68253591aa
Jeep Wrangler JL JD Powers Survey 2023-11-17 11_52_19-Window
Spring 4 68253592AA https://parts.moparonlineparts.com/oem-parts/mopar-rear-coil-spring-68253592aa
Jeep Wrangler JL JD Powers Survey 2023-11-17 11_52_50-Window
As you can clearly see in the boxes There are multiple models listed per spring, proving that I was correct in saying that springs can be for multiple models.
If you really want to check your spring #s create an im with Benny @AllMoparParts.com and send him your vin and ask him to look up the springs that go with your Jeep.
Also I would recommend allmoparparts.com over moparpartsonline It took them 8 months to get me something allmoparparts took 3 months to send and I ordered it 4 months after I ordered from moparonlineparts
I am trying to help, but you are not making it easy. Use this post as an example of how to prove your claims in the future.
yokramer
Snark Incarnate
yokramer
Snark Incarnate
You will notice that 2 door is even listed furthering my point even further as there is no 2 door XR option.
hhttps://parts.moparonlineparts.com/search?search_str=68254661AD
This will not sway his opinion 1 bit. Him thinking an internet parts catalog is going to be anywhere near right on things like this proves he doesnt know how any of it works just wants to be mad.
John Benoit
Loveland, Ohio
You didn’t post the springs that are actually on my Jeep. Come on, be fair
yokramer
Snark Incarnate
gek
Code Monkey
I am going to leave that to you. I merely posted how your proposed springs do not prove that they are 1 1/2" higher. And prove that my point that just because springs are on a certain Jeep does not mean that they don't work on another.
I did look at yours, and I did not see proof that they are the the wrong ones, but you can make that argument in your next post showing them, as I may have missed something.
SaintNick
St. George, Utah
2023 Jeep JLU High Tide
If anyone else has a bump stop 1 inch away from the front axle, got screwed the same way I did. They need to check the part number on their springs. Here your proof
My High Tide has about 3 fingers space, but there are no tags on the springs so I can't confirm.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
John Benoit
Loveland, Ohio
More deflection. More bs. Do you guys live on a farm? It sure smells like it.
2nd 392
Ca
Are you seriously going to continue to say completely fallacious crap like this, even after being shown irrefutable evidence to the contrary?
Seriously??
Sooo- I see that you have ignored “pattern confirmed, explanation futile” recommendation from many pages ago yesterday and are continuing your attempts of persuading delusions with reality……….. Uh Oh—
Jeep Wrangler JL JD Powers Survey AFDC64FD-6CA4-4D9F-ABA6-93AF9E0E8E22
Too now
John Benoit
Loveland, Ohio
Look at the top of the spring there should be a paper tag. It is hard to see and difficult to photograph.
gek
Code Monkey
There is no deflection or BS, merely my not doing your work for you. If you are too lazy to make your own arguments then there is no helping you. You must've never been on a farm because you seem to be scared of putting forth some effort and doing some of your own work.
You want to prove your springs are wrong then f'n prove it. It is not on me to disprove your accusations it is on you to prove it and if I disagree then it is on me to disprove you.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
OP people are actually trying to help you, but your inability to accept a possible reality where you are totally wrong and lashing out at others in response to their attempts at helping you, might indicate you have a narcissistic personality disorder and my friendly advice is to seek professional help.
https://psychcentral.com/disorders/narcissistic-personality-disorder
"This is why they might feel attacked when you contradict them or tell them they’ve done something wrong. This just doesn’t align with their inflated sense of self.
This is part of the complexity of narcissistic personality disorder.
The tendency to have low introspection combined with an exaggerated sense of superiority may leave them unable to see the situation in a way that doesn’t fit their worldview.
As a result, they may “play the victim role” in some scenarios."
gek
Code Monkey
Jeep Wrangler JL JD Powers Survey wojak-dark-hole
Status
