JD Powers Survey
Status
Not open for further replies.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
The point which and everyone else can’t seem to grasp is if their XR only has one inch of clearance between the bump stops and the front axle, they probably got screwed the same as me. They should be checking those spring part numbers to see. But the gang would rather attack me. Why can’t you let it go.
I don't know anything about your XR's springs or bump stops. I'm just pointing on the obvious fallacies that you're clinging onto related to the engine cover and how it's all a conspiracy against you.
No dice on admitting that you might have been mistaken about the engine cover? That you might have overreacted?
John Benoit
Loveland, Ohio
2023 Jeep Wrangler Rubicon Unlimited
You’re trying to defend Jeep for ripping peopleoff.
Ratbert
PNW
Software Engineer
You definitely must work for Jeep with you constantly trying to deflect my responses. You need to let it go. Please don’t respond to this thread again.
Have you at least learned enough about how the internet works to admit that I didn't do what you accused me of? That you, yourself, put the OP banner on your name plaque and that I wasn't part of a conspiracy against you to do that?
I am about tired of you thinking you run this whole forum and want to sabotage other peoples posts. I don’t feel you have the right to put a banner on someone else’s name plaque to tell everyone else to attack them I think you should kicked off of the JL forum.
John Benoit
Loveland, Ohio
Here you go again deflecting.
Ratbert
PNW
Software Engineer
No, I'm showing that your perception of reality might not match reality. Jeep definitely cut corners, but we all knew about those corners being cut at least nine months before you ordered yours and accepted it without popping the hood.
You didn't know. Get over it.
John Benoit
Loveland, Ohio
Why didn’t you inform me ahead of time? Or you could have informed me this stuff was already discussed. Maybe it is because your selling Jeeps.
BuyHold
Tim
Washington
'21 2-Dr Rubi, '23 JTM
After 23 pages of insightful discussion, sharing of knowledge and playful bantering, I am thoroughly convinced that our little Jeep forum has convinced OP (Mssr Benoit) to petition JD Powers for an opportunity to retract his original response so he can proclaim he was mistaken the whole time, set the the record straight and officially declare that JEEP DOES CARE.
yokramer
Snark Incarnate
John Benoit
Loveland, Ohio
Not hardly.
yokramer
Snark Incarnate
Oh no Jeep dont give 1 single fuck about any of us here ... just not in the way Mr. Benoit has deluded himself to.
Status
