Interior Rotopax mounting for water pack
Caveman044
PNW
2022 JLURXR
Anyone have a solution? I've seen JK's mount them to the rear roll bar, is there something for the JL?
SadRobot
Los Angeles
2025 Prius LE
I wasn't able to find anything pre-made to buy so I made my own. I had to remove the plastic cover around the seat belt and put a u-bolt around the roll bar inside.
The Rotopax mount is then attached to that u-bolt through some holes I drilled into the plastic. Seems to be holding up really well although I only usually fill the Rotopax half full to keep the weight down.
Edit to add photo I took during install last year:
I forgot I couldn't get the ubolt to line up to where I wanted the Rotopax to be so I added some mounting plates and only could put 1 bolt from that into the plastic.
Jeep Wrangler JL Interior Rotopax mounting for water pack IMG_1861
JINO
Jino
Socal
2021 jlurd
I had these molle panels in the rear windows (inside). Would easily take a rotopax mount, but unsure if the rotopax would fit.
Jeep Wrangler JL Interior Rotopax mounting for water pack 20231202_155933
