Installing a Digital Rear View Mirror / Dash Cam
yarmo
Jack
CO || DC
'21 JLURD
Engineer
I recently shifted my spare tire to be higher on my tire carrier to accommodate a new rear bumper, and I lost almost all visibility out of my rear view mirror. So to fix that issue I installed a digital rear view mirror that also doubles as a dash camera! This is the mirror I went with. There are some out there that are more expensive and some that are less, but I chose this one because it's almost exactly the same width as the factory one, so you can still open and shut the sun visors normally.
I have a JL with the SOT top and ACC, so your install may be different than mine. Here's a good video on the general removal of a rear view mirror without my setup. The process is basically the same with the SOT / ACC, but the first thing you need to do is remove the 4 plastic screws and plugs from around the ACC cover trim.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam Screenshot 2024-01-29 at 5.50.04 PM
Then pop off the little vented cover in front of the panel you just removed the screws from (two clips on the top). After that you can do what the above video mentions and pull down on the top trim.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_4476
Again, follow the video instructions and use a screwdriver to twist your rear view mirror to the left to pop it out. Then disconnect the wiring harness if yours is equipped with one.
Here's where the process got tricky - the camera I bought did not come with a mount that would fit the JL. Their "Chrysler" mount was not setup to work with a JL at all, so I had to 'aggressively' modify one of the mounts they sent. If you look up from where you just took the rear view mirror out, you'll see 3 torx bolts holding the factory rear view mirror mount. I removed the 3 of those then modified the supplied mount you would normally glue to the windshield to screw into the center hole. I did my best to bore it out enough to fit one of the torx bolts under where the new mirror would slide into it.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_4475
Here's where I mounted it next to the factory mount for reference. I stacked 5 washers on top of this to get it to mount a little further under the trim. If you don't use a bunch of washers you won't have clearance to adjust or move the mirror at all due to it hitting the trim.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_4477
After you get the mount tightened down, you will probably have to snip a few pieces of plastic trim around the mirror mount in order for the SOT / ACC trim to clear it. After that it's as simple as running the wiring to ACC / Battery power (this required BOTH to be run for some reason and would not turn on if not done so!!), then running the wiring / mounting the rear camera.
This is a much better alternative to having 0 rearview visibility!
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_4480
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
How bright is it at night? does it auto adjust based on the available light
Also did you have to install a separate camera for the video feed and it will not re-use the stock rear camera as is?
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
It is auto dimming, but you can also manually adjust it if needed. It's as bright as a dimmed rear view mirror would be with someone's lights on behind you. The night visibility isn't amazing, but again this is still better for me than having 0 visibility.
You do need to install a separate camera for the video feed which it comes with. I have it mounted in the top center of my rear glass via adhesive tape (it came with). Unfortunately I don't think this kit would work well with a soft top. There are others out there that would, but I don't know of any that use the existing rear camera feed, and I think that angle is too low anyways.
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
Here’s the view at night it’s pretty good honestly.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_4483
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
I recently shifted my spare tire to be higher on my tire carrier to accommodate a new rear bumper, and I lost almost all visibility out of my rear view mirror. So to fix that issue...
I installed a bumper with a tire carrier and installed the carrier as high as possible to raise the spare as much as possible.
I use the side mirrors for rear view.
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
Living in the city I like to know what the car right behind me is doing, and I don’t get a solid view out of the side view mirrors. Have to keep your head on a swivel at stop lights unfortunately.
Kraxler
Rio Rancho, NM
JLUR Diesel 2021
I did a similar thing. I used: Brandmotion FullVUE Rear Camera Mirror for Jeep Wrangler JK/JL - Gladiator JT FVMR-8886 Touch Screen Mirror/Backup View | Always-On Dash and Rear Cam | G-Shock Sensor | Waterproof l HD 32GB Card.
It mounts right up to the factory mounting holes. The mirror clears the visors. I mounted the camera to the rear cargo rack above the spare tire. Works great.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam image
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
Ageek
Maryland
2023 4XE JLU Rubicon
How wide is the wolf box? When I ordered that one it was so wide I couldn't fold the sun visors down.
I just finished my Wolfbox G900 install last night. The angle I have the mirror at lets the passenger visor barely come down, but the driver visor cannot come all the way down.
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_0707
Jeep Wrangler JL Installing a Digital Rear View Mirror / Dash Cam IMG_0708
marktgorman
Ohio
www.underblue.com
Wrangler JLU XR
I tossed on a @Diode Dynamics hitch receiver light and it makes a big difference. The aftermarket tails lights I had (from someone else) were not great when backing up. $100 is well worth it, especially when backing out of our driveway at night.
https://www.diodedynamics.com/hitchmount-led-pod-reverse-kit-for-2018-2023-jeep-wrangler.html
Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
2018 Jeep Wrangler
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Good info all around, thanks!
This is definitely on my short-list to do, but I I've pretty much ruled out the Wolfbox G900 due to the width interfering with the visors and the appearance of all the plugs sticking out of the top. I will absolutely not be strapping anything over my OEM mirror either, that's just a pathetic design. I also have a SOT and ACC, so I have the large plastic housing to contend with potentially blocking the front camera view.
I see that Auto-Vox makes a T9PRO, which has a detached front camera that could be attached to the bottom of the ACC housing and completely eliminate it from view. I can't find any pics that show where the wiring attaches to the Auto-Vox though, any chance you have a pic of that @yarmo and also possibly a shot of how your front cam looks with ACC box in front of it?
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
The front camera view is not ideal it captures ~1/3 of the frame under the left side of the ACC box then the right side is completely fine. It's good enough for me, but I wish I had gone with the T9PRO; I was unaware they had that model. I'd do that if I were you.
The wiring is very simple they have it setup so one single wire goes out the top of the mirror, then 5 feet away it breaks up into different wires for power, ground, backup cam, gps, etc. I'd imagine the T9PRO has a similar setup with another wire for the front cam closer to the plug that goes into the mirror.
dlong1119
Gainesville, FL
Thanks! So does the wiring come out of the back of the mirror where the mount is? And where does the SD card plug in? I've sent Auto-Vox an email to see if they have a direct mount for our Jeeps.
