Installing a Digital Rear View Mirror / Dash Cam
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
Thanks! So does the wiring come out of the back of the mirror where the mount is? And where does the SD card plug in? I've sent Auto-Vox an email to see if they have a direct mount for our Jeeps.
I can't get a good picture of it the way I have it mounted unfortunately, but the wiring comes out of the back of the camera and then goes up through the mount into the trim. The SD card plugs in at the bottom there's a panel you can pop off to insert it. It's easy to get to while mounted in my Jeep.
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Perfect, thanks! I downloaded the manual for the T9Pro and that's what it looked like but they never really give a clear picture of it.
81bronco
Raleigh
Greenville, SC
2021 JLU ecoDiesel
How wide is the wolf box? When I ordered that one it was so wide I couldn't fold the sun visors down.
I ordered the G930 specifically because it was the narrowest Wolfbox (10"). Passenger side is very clear. If it is angled just right, the driver's side clears as well.
underwaterpiano
phoenix
2021 4xe
Hi, thanks for the post. Is your front dashcam on the back of the digital rearview mirror able to see past the sensor package plastic setup ?
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
dlong1119
Gainesville, FL
No, it’s not. I ended up changing the camera to be this one instead that has a separate camera for front facing dash cam.
Are you happy with the T9Pro so far? I'm finally circling back around to this project again and am getting close to ordering one. Did you do anything different for your mount or are you still using the modified stock one from the beginning of this thread? I had emailed the manufacturer and it sounds like they offer a mount that will bolt right up to our Jeeps with the ACC style mirror mount.
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
Yeah I swapped it out for the mount they offer. It’s a much better fit. I’m still very happy with it!
dlong1119
Gainesville, FL
Did you have to contact the company to order the mount or did you find it on Amazon? Was there an additional charge for it?
yarmo
yarmo
Jack
CO || DC
'21 JLURD
Engineer
I did contact the company and they sent me the mount for free. The way they did it was refunding the cost from my initial purchase. They're actually very nice to work with and are pretty responsive. This is the exact mount it's only $26.
dlong1119
Gainesville, FL
Awesome, thanks! Planning to place my order this evening.
Huntertodd80
Hunter
Charlotte
2018 Jeep Wrangler JL Unlimited Sport
Sent you a DM but figured I would revive this thread, did you remove the entire ACC box to get access to the original rear view mirror mount with the 3bolts attacthed to the frame
hammten
WI
2021 PBJ JLUR 4xe
This video may be of some use for your inquiry. It's for deleting the rearview mirror entirely, but it demonstrates how to get access to the 3 bolts that hold the mirror bracket to the mounting point.
