Installed beadlocks, now steering wandering - fix?
Push your fuses in. ;)
It's the longer moment arm created by moving the tire outboard. You put a cheater bar on the tires that is putting more force into the steering system and trackbar.
joetimmons
joetimmons
Jacksonville FL
2022 JL
Update - aired down to 32 and then tried 30 psi and didn't seem to help much still getting a left/right/left/right wandering, especially at 50-60mph, and aggravated if I hit a dip in the road.
Going to check the alignment tomorrow, but if that test/adjustment fails I think my lesson learned here is that no matter what if you try to get too cute by adding bead locks to a stock non-adjustable track bar and/or non-adjustable control arm(s) to calibrate and adjust caster you are asking for wandering.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
He has the 315s from the XR. What did you run your 35s at? I know that was FOREVER ago ?
The details are starting to fade, but I can still remember 30-31psi being the happy spot for my 315 ko2's way back then. ?
Hard to believe you had such tiny tires, once upon a time.
Headbarcode
LI, New York
Once upon a time, back when my wallet could still walk on its own and handle solid foods...
Jeep Wrangler JL Installed beadlocks, now steering wandering - fix? 20200423_092730
One of these days, the beatings will end and it'll be left alone long enough to fully recover. Probably not, but that's what I'm telling it...
Jeep Wrangler JL Installed beadlocks, now steering wandering - fix? wallet
Jeep Wrangler JL Installed beadlocks, now steering wandering - fix? 20220806_091606
Jeep Wrangler JL Installed beadlocks, now steering wandering - fix? gangs-of-new-york-that-was-the-finest-beating-i-ever-took
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
-38 crew checking in. Ran stock steering, trackbar, and ball joints like this for nearly 2 years after getting longer lower control arms to correct caster. Now I've upgraded almost everything, but the offset is definitely manageable once you correct the angles. Your stock caster on an XR with stock control arms is probably pretty low. That will definitely make it squirrely
Jeep Wrangler JL Installed beadlocks, now steering wandering - fix? imgly_94365089168014052
mgroeger
Southern UT
2021 JLUR 2.0T
You moved each wheel out by 3.25" inches. That's what's ruined your steering and your ball joints will be destroyed in a year. 37s won't help you. Try -6mm offset at most. +12mm is better if you can find wheels in it.
LOL... that's funny... ball joints destroyed in a year and steering horrible. I had -38mm on a few Jeeps and after 9 months my ball joints blew apart while I was going 80 mph on the highway. Oh wait, never mind that didn't happened.
mgroeger
Southern UT
2021 JLUR 2.0T
Crap ok well hoping I don’t have to send back the rims and rebuy a lower offset but so is life
Don't listen to that asshat. I've run -38mm beadlocks on multiple jeeps with no problems. Most likely what you are experiencing is caster related OR the way you mounted your tires. Did you research what color dot was on your tire (red or yellow) and mount the tire accordingly with that dot in relation to the valve stem? Did you properly and painstakingly torque down every bolt in MULTIPLE steps and NOT IN A CIRCLE to 20 ft/lbs? Did you take them to a competent shop and have them balanced? Preferably one who has experience with heavier wheels like beadlocks?
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Same here.. I have been running 17x9 -38mm offset with 40'' tires, stock arms + arm relocation bracket and 3.5 Gamechanger springs for 2 years with no issues... and yes.. I daily drive it.. and yes.. I run difficult trails.. my rig still drives 80MPH on the highway with no issues.. no wandering.
Deleted User 38384
It could also be your imagination, not to say that it is, but every time I rotate my tires, I feel like something's wrong with my wheels for the first thousand or so miles. And then after that I worry less. Though I had a friend of mine get some new rims put on his wife's Wrangler Sport, and had them balance and everything, then he got the steering wobble, so after a lot of trouble, he ended up figuring out that it was the wheels. Whoever balance them didn't know what they were doing and did the weights all wrong. So technically it could be the weights too.
Tpsillos
Trey
South Carolina
2021 JLUD
Welding Inspector
Does nobody on the JL Forum run -38mm / 3.5" backspace? Didn't realize it was such a purple squirrel config haha
Was hoping once I get the adjustable arms I can re dial the caster in as mentioned above...
nothing wrong with 3.5” back space, I did have to change ball joints after a year but my friends with a stock gladiator did too…
