Install question
kantho
Karl
San Marcos, CA
2018 JL Sport 2 door with premium soft top
I just bought a Tazer JL Lite (from Quadratec) and am reading the manual. I have updated the firmware but I have a quick easy question or two.
I install the Tazer by unplugging the SGW module and putting the Tazer in its place, correct? What is the SGW module?
Secondly if I want to just use it to change the settings then remove it from the vehicle do I plug the SGW module back in? I want to leave my changed settings in place. Not planning to UNMARRY it, just remove it.
Thanks
Multiple places..
@kantho
The video below is not in regard to the Tazer JL Mini but it does show how you access the SWG gateway, module, where it is etc.. Watch the video.
Yes, you disconnect both wires from the SWG and those disconnected wires plug into the Tazer JL Mini.
IF you want to use Live features, you MUST leave the Tazer JL Mini married and the Tazer JL Mini, hooked up to the 2 wires !
I can't imagine you would not keep it hooked up as the much desired, ESS disable is a live feature.
SO, my recommendation is leave the Tazer JL Mini married and attached. Only unmarry and remove the Tazer JL and reattach the SWG cables if you take the JL to the dealership Service Dept.
Note: Suggest you go to the ZAutomotive website and buy / pay $20 for the available 2 yr. warranty.
Don't care for this video much but it will give you the info you seek.. Forward it to 4:35 min. point and start watching from there...
Multiple places..
Pics...
Jeep Wrangler JL Install question Remove panel
Jeep Wrangler JL Install question 20180426_194230
Multiple places..
Install hints:
Pull panel below the steering column straight out and off. Careful not to lose any of the 6 white plastic female connectors that can fly off the black panel.
Don't even bother trying to do the install if you do not have a bright light in the passenger footwell to light things up well under there.
Locate the SWG. Do know that each of the 2 wires that you will be dealing with have a push in release tab so to speak on the connector that you have to push in firmly on, in order to get the connector to release. This release is on the back side if the connector, the side closest to the firewall. BEST BET, is to first push upward / push the cable inward. Now, push firmly on the release and at the same exact time, pull downward on the cable itself. Sometimes a little wiggle of the cable while pulling the cable firmly will help you get it disconnected.
When reinstalling the black plastic, go easy.. start at top and work down. Push straight in. Don't be overly rough or you may damage the black male that holds the white plastic female.
kantho
kantho
Karl
San Marcos, CA
Install hints:
Thanks for all the great detail, photos and recommendations. I am not a fan of those plastic fittings that can easily snap off with the wrong amount of force or wrong direction so your advice is quite meaningful. "straight out" tells me what I need vs straight down. :)
FrostQ
Canada
Rubicon
How the F#^*&#^*&^ do you remove the SGW plugs...I've located it...bloodied my knuckles trying to unplug the damn thing. It won't come off!
Multiple places..
@FrostQ
First off, have a good light source to light up the working field.
Install hints:
Note: Teen Sons / Daughter or Wife seem to be able to easily do the disconnect... Small hands!
Do yourself a favor and buy the SGW Extension Cable from ZAutomotive... Makes life easier lets say..
FrostQ
Canada
Rubicon
Yeah I've tried your tips you posted earlier. But the cable won't come loose. I've resorted to my last option to ask someone online how to remove a connector...lol.
Multiple places..
@FrostQ
When you push firmly up, push in on little disconnect.... at same time wiggle wiggle wiggle in different directions as you pull downward.. Sometimes connector plastic edges catch a bit and keep the connector from coming free easily..
Cuss at it in French... that might help.
Try again... if a no go, take a break and try again... It is a pain but you will get it. Don't discount my suggestion of sicking a smaller set of hands on it.
DO, do buy the SGW Extension Cable!!!!!!!!!!!!!!!!!!!!!!!!!!!
dpike
New Jersey
'20 JLUR 3.6
@FrostQ
! this !
i think last time i removed my tazer i resorted the a long flatblade screwrdiver that i used to press the tab in. still sucked and i still tore my hands up pretty bad.
Multiple places..
! this !
@dpike
I don't encourage using a screwdriver, etc. as I am afraid the guy/gal will damage the connector, female.
Ripsaw502
Millersport, Ohio
2018 WRANGLER UNLIMITED RUBICON 4X4
Dump truck Driver
@FrostQ
Install hints:
I love how they make it look so easy in there video yea not so much. I even had the wife try nope AAAARRRGH and we had no luck .
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
For those playing along at home, if you have a 2024 I think the space is even tighter. The first time I tried to get mine out I ended up giving up, and then came back the next day with a bit more patience and finally got it.
rohdawg
Long Island, New York
Merchant Marine
100% agree.
I’ve tried three separate times now and keep failing to get even one of the connectors to budge.
