How to prevent pocket panic pressing?
ecomguy
Mitchell
Seattle, WA
Audi A3 etron
The Jeep key fob, being the size of early-00’s flip phone, is really great at getting jammed against my other keys in my pocket and setting off the panic button. I’d prefer not to annoy the neighbors unintentionally.
Does anyone have any elegant solutions to prevent unintended button presses without adding even more bulk to the huge key fob?
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
Terrymo
Terry
2023 JLURXR 3.6 ET
If you don’t want the panic alarm to function at all.
Disable Factory Key Fob, Panic Button Hack...
To temporarily... to mechanically disable the Jl/JT factory fob panic button.....
Open up the fob and with a small tweezer, gently remove/pull the small black piece of rubber off of the circuit board contact associated with the panic alarm. That's it!
The small black piece of rubber is easily put back in place should you ever want to do so.
For terrific info in regard to the JL/JT fob, read here:
https://www.jlwranglerforums.com/forum/threads/?-fob-101-know-thy-jl-key-fob?.88719/
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Excellent point. If you're in a situation where (for whatever reason) you need the panic button, then you're most likely too panicked to remember that the button is there.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
I don’t have this problem :LOL: .
Jeep Wrangler JL How to prevent pocket panic pressing? IMG_8220
jadmt
jeff
montana
Just leave the fob in the center console permanently. Problem solved.
might get lucky and someone might actually steal it...my luck they would realize they made a mistake and they would return it before insurance paid it off....
Wbino
NJ
Buy looser pants? 🙃
Or buy those keychains which hang outside your pants?
Operative73
Christian
Pittsburgh PA
2020 Wrangler Sport S/2017 Softail Breakout
I disabled panic through the Tazer Mini(lots of reason to get a Tazer). I only had a few accidental panic activations but that was enough. I also clipped the catch part of the spring that flips the key out. I had more issues with the key button getting pressed causing the key to flip out, now it's a gravity flick to get it.
mysto
Sting Grey 2 door JL Rubicon
Yes! I disabled it and replaced the fob. Without a tazer I would have put glue in the buttons or something as there are few things I like less than features and this is clearly a feature.
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
I don't have keys attached to any of my fobs. I repurposed a leather belt holster for a Leatherman OHT that I used to use at work. It holds my Jeep fob just right, and my other key fobs a little looser- of course! :CWL:
While mine is a local, hand-made item, similar ones can be had from Etsy, with options for color, belt clips, AND size. Get it big enough for your Brick, and it'll probably hold anything!
https://www.etsy.com/listing/181984...14b0:3d8aea8ca65e5f88f9253c03cbdc4b65ab272751
