How do I get this off?
Deleted member 59498
Guest
Clorox spray bottle of bleach foam stuff? Cleans the bathtub like a champ! Just don't breath real deep!
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Just picked up a used hardtop and the freedom panels are covered in this stuff. I've tried a magic eraser, dish detergent, etc and nothing works..any idea how to get this clean?
Try this.
Concentrated Stain Remover, removes coffee tea and other stains and useful in heat transfer technique. Alkaline Spotter are useful for protein base stains such as blood, some food stains and some inks, pigments and dye.
Application: Use 100 to 140ml per litre of made up solution and use as soon as possible. The mix is suitable for use with heat transfer techniques when attempting to remove foreign dye stains.
Jeep Wrangler JL How do I get this off? 1654314792954
SouthValleyPerformance
JD
Arizona
2022? Rubicon
I’d say either some low concentrate bleach or just paint them black. Solves the problem AND looks better.
Quick
CT, USA
I’ve previously used isopropyl alcohol to clean the tops when installing Hotheads Headliners. That worked better than any other option I tried.
Edit: I have also used acetone pre install
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Just be careful that what you use won’t melt styrofoam?
californiajeeping
JLUR
Try rubbing alcohol with 90% Isopropyl and then try hydrogen peroxide. And use a sponge that has a rough side on it.
Jeepney Johnny
Rico!
2020 Jeep Wrangler Sahara
If you're willing to try something abrasive and have the dexterity for a light-handed gentle scrub, a paste of baking soda and a drill brush attachment might remove those stains or might just be prep for painting? There's a lot of these scrubbers on Amazon:
Jeep Wrangler JL How do I get this off? 1654349757977
Good luck.
Initial-Jeep
Julian
. Greensboro, North Carolina
'22 392XR Tuscadero, PT Cruiser Dream Cruisers 2&4
Data Engineer, Retired Air Force
I agree with Smcdowell; I would try a Sodium percarbonate product as well (OxiClean, Cafiza, et al.) and let it sit overnight.
keeperman13
Jamie
Suwanee, GA
Ford Explorer, Honda CRV, Ordered JLUR
Mortar Manufacture
Steam it. Those steam cleaners are impressive
Pinky Tuscadero
Kenosha Wi
2021 Pink RHD Wrangler 2015 RHD Wrangler
Sorry for the stupid question if you did but, did you wet the magic eraser ?
I've seen a couple people try using them dry and cuss till I poured water on them for them
I cleaned 2 hard tops that we sat outside in the grass every year with those and everything comes off
If you did wet it, try those other ideas... please be safe, you get those chemicals in your eyes or lungs and it could be a lifetime issue ?
