How are you jacking the front axle
c20040215
Leon
Indiana
I have a floor jack and like to lift from under the spring perch, but the lifty thingy doesn't sit on the axle well at all and has slipped. I've only lifted it for tire rotations, but it's frightening.
What are you guys doing/using?
If I only need the lift it up for a quick tire change, I use the lower control arm mounts. I have Artec truss which came with skids. They are nice lift points. If I need to place jack stands, those are also the go to spots. I just need to lift up the axle from the pumpkin, high enough to slide the jack stands to those spots.
P.s. If you say a post lift or something similar I'm going to create an OF in your name and post feet pics.
No, you cant. I already have an OF with feet pics.
yokramer
Snark Incarnate
I understand the physics behind air jacks and air-ride suspension and I know it's as safe a method of lifting heavy things as steel and hydraulics... but I don't think I could work under a Jeep lifted that way. I just can't get past the fact they look like a balloon on steroids. :)
I would hope they then put a solid jackstand under there after its lifted
Blues Fan 30
St. Louis
Tbf fire departments use airbags to lift vehicles every single day.
ASSFROW
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
I'm not using your feet, so you are really fucked.
yokramer
Snark Incarnate
Not to work underneath them. Shops used to have hydraulic in ground lifts and even they had locks on them to hold them in place so if the air failed it didnt come right down.
