help I'm going crazy
AC1982
Alonso
Costa Rica
Wrangler Rubicon Unlimited JL
Hi new here, I have a problem with my JLRU and I would appreciate any advice.
Driving early at low speed the car shows a check engine light, after that the car feels with no power if I accelerate over 3k
Come back home, check and the DTC is U1514-87, clear the code and I take the car for a test but 6km later it comes again.
This time I clear the code but check engine light is still there.
I take off the battery cables to reset but it was worse, Now I had the U018-00, U1514-87, the radio is dead, the sway bar and the start-stop lights are on. The voltage is around 11v when car is on.
I replace both batteries 2 months ago, and I don't know what to do.
Has anyone been through this?
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
Check to make sure all the fuses are fully seated in the underhood electrical center. I am not familiar with U018-00.
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
Check your batteries, all kinds of crazy things happen when batteries start to fail.
garykk
Gary
Southern NM
2022 JLURD
Do you have a Tazer? Check the bus behind the glove box.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Your voltage is too low, with the jeep running it should be like 14.5 volts. You might need to have your alternator looked at.
AC1982
AC1982
Alonso
Costa Rica
yes, with tazer I clear the dtc. I unmarry the tazer and remove it completly but no luck.
Steve JLUR
CoS, CO
2021 JLUR
Quit calling it a “car”, that should fix ALL your problems.
Really, sorry you are having issues.
1quick1
Moderator
Moderator
2018 JLUS
Are you still under warranty? I imagine warranties are different in Costa Rica or maybe not?
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
First, you have to understand that clearing an error code doesn’t fix the problem. I agree with making sure that all fuses are seated properly and that if all good, then I’d have the alternator checked.
Opus
Midwest US
www.jlwranglerforums.com
Yeah. Having replaced the batteries fairly recently, the next likely culprit is going to be the alternator. Meanwhile, check fuses and make sure all your battery terminal connections are snug.
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
Every time I see weird unexplainable issues like this it always comes back to the dumb battery setup in our Jeeps. If both your batteries have been recently replaced, then as another suggested, check the alternator. It might have been working overtime to compensate for your previous failing battery. Electrical gremlins unfortunately plague modern vehicles and can be difficult to diagnose.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Double check your new batteries, you may have possibly gotten a defective battery.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
How did you replace the batteries?
Check your main bus bar fuse array.
AC1982
AC1982
Alonso
Costa Rica
I fix that, but now the car shows dtc B16D7-15, the car runs but slowly over 2K rpm.
Any idea what could it be
