ssiegler
This makes me hate it even more than I did before. You would think that if the AC is the cause for it turning on, it would be able to sense this and not shut the engine off only to start it up again 30 seconds laterPer User's Manual:
Conditions That Will Cause The Engine To Start Automatically While In Autostop Mode:
• The transmission selector is moved out of DRIVE.
• To maintain cabin temperature comfort.
• Actual cabin temperature is significantly different than
temperature set on Auto HVAC.
• HVAC is set to full defrost mode.
• HVAC system temperature or fan speed is manually
adjusted.
• Battery voltage drops too low.
• Low brake vacuum (e.g. after several brake pedal applications).
• STOP/START OFF switch is pushed.
• A STOP/START system error occurs.
• STOP/START AUTO STOP ACTIVE time exceeds 5
minutes.
• 4WD system is put into 4LO or Neutral mode.
• Steering wheel is turned beyond threshold. (ESS Models
Only)
