oceanblue2019
- John
- Apr 13, 2019
- Northern Arizona
- 2019 JLUR 2.0L Auto
- Occupation
- Consultant
Anti-sway bars are about being able to transfer enough of the inertia energy that causes the sway to the inboard wheel to artificially reduce the spring rate to level out the vehicle; which reduces/eliminates sway. In essence the vehicle will squat to reduce the sway.It's definitely worth noting that the Antirocks are purposely designed to work best when both the fronts and rears are paired together. I have their JL specific .770" bars front and rear, and I've only noticed a marginal increase in body roll when flinging it through curves and corners. I didn't go with the optional JK specific .880 bars because all of the weight that I've added to my Jeep is at and below the frame rails.
This change was one of my most researched, because it's also my daily driver and I am specifically not wanting to cross the thin line of ending up with a jeep that is a big compromise on road. Most of the on road complaints that I dug up were centered around previous generation Jeeps, which have their rear shocks mounted inboard of the frame vs outboard like our JL's. Most of the JL complaints seemed to stem from only having a front or a rear setup. A stiffer and connected factory front will cause the rear Antirock to give sooner and more so, because the balance is off.
The higher the center of gravity and the weight of the vehicle the tougher this becomes to do. And the more you succeed the worse articulation becomes off road And even harshness on rough pavement.
You can not have both — which is why the Rubi has the disco from the factory to get you a way to have both.
The anti-rocks are thinner and longer lever arms then the factory bars. Most guys run them as they look cool and deny the Jeep drives like shit on the road at speed after install because…..they look cool…..
I have no idea why someone would remove a Rubi front for an Antirock as it’s step backwards.
……… ok…….
