Has it Happened
yokramer
Snark Incarnate
I don’t, and my adblocker says no to that, but I believe you.
Its essentially a bot 20 questions. Just AI does all the questions where you cant see and makes stuff up.
Terrymo
Terry
2023 JLURXR 3.6 ET
Like this nonsense below gleaned from ChatGPT with a cite from Reddit. (The 3.6 is obviously superior And this is chatbot BS)
Many owners note the 2.0 turbo delivers stronger low-end torque, great for passing and mid-range response: “2.0 has more lower end torque… The 2.0 L has more zip, no question about it.”
yokramer
Snark Incarnate
Even blind squirrels find a nut occasionally.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Doesn‘t ChatGPT use publicly available data which includes Reddit, Wikipedia, and even this forum? If so, won’t the most parroted misnomers be incorrectly weighted and have a greater chance of being repeated on ChatGPT? For example, make sure all your fuses are firmly seated, at one point, was the answer to every electrical problem on this forum.
Yes. I should have clarified that I was referring to @jeepingib's statement:
By reading them you would think that they are perfectly fine, and no issues could be had by using them.
It doesn't in any way imply that the aux is perfectly fine.
Ratbert
PNW
Software Engineer
I'm guessing it also gave alternative perspectives as well, right? It's improved dramatically in recent years, especially with v5.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I was referring to the A.I. summaries that were previously posted in this thread. You can get the A.I. bot to say pretty much anything you want to support your viewpoint. It's all in how you phrase the line of questions.
Ratbert
PNW
Software Engineer
It can be fun to see it get flustered if you ask it if it's hallucinating.
I can just imagine flat earthers (flerfs) trying to coerce it into agreeing with their stance.
Ratbert
PNW
Software Engineer
I need to go back and edit it to clarify that ChatGPT was summarizing that specific post and not the subject.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I never used AI you guys. I don't even know how. I don't suspect I want to know either. With me you get Ol' one eye Willy. 😉
I can't post gifs anymore, at times I can barely upload a photo. I'm getting worse everyday.
Jeep Wrangler JL Has it Happened IMG_2284-1578869728
Terrymo
Terry
2023 JLURXR 3.6 ET
Same brother…same…no respect for their elders I tell you.
Wbino
NJ
I don’t understand the technology, but at this point it reminds me of the early stages of Wikipedia where anyone bored enough could contribute an article based fully on nonsense. Garbage in garbage out.
My understanding its a just combo of:
Google search + cut/copy/paste= All wrapped up in one application.
Terrymo
Terry
2023 JLURXR 3.6 ET
My thought is if someone posts the same erroneous info on this forum enough times it will get cited as a valid answer.
Wbino
NJ
So angry grilles don't cause cancer?
yokramer
Snark Incarnate
Like for sure 100% the Gladiator is going to get the 392.
