Hanging top from garage ceiling.
Mthayeck
North Jersey
2020 Wrangler JL Sport S Unlimited
Have any of you hung your hardtop vertically from the ceiling using the front mounting holes? My ceiling in the garage is too low to hang it like it sits on the Jeep but I have room to hang it vertically in the corner where it wouldn’t get in the way. Just worried that the holes wouldn’t support the weight. Thanks in advance and any pics would be great!!!
Jeep Wrangler JL Hanging top from garage ceiling. B1FF21A3-E65E-499E-9B52-74379562BB77
WontonJLUR
Suffolk, VA
2019 JLU Rubicon
I would not do that.
Just install some D rings or eyelets in the ceiling, then run a few straps underneath the hardtop as the above poster suggested. Get some pool noodles to put on top of the top then you can cinch it all the way up to the ceiling
If you have any kind of wood working ability (we're talking the most basic possible here) put some threaded inserts in a 2x4 that's cut to about the length of the bottom part of the top. Then run some bolts through the hard top mounting holes to secure the 2x4 to the top, and then you can run the strap under that. Keeps the strap off of the paint and reduces the stress on that tiny little edge.
I used to have that setup, I'll see if I have any pics
Tellurian
Earth
I would be more inclined to use a couple of wide webbing straps around the the hardtop to form a cradle. It would spread any load over much more area and likely be more secure.
Agreed. That would be a lot of weight to support from those two mounting points. Maybe use them to secure it in the upright position at most but definitely not to hold it up.
Out of curiosity, how is it that the ceiling is too low to hold it as it sits on the Jeep but tall enough to hang the top vertically?
WontonJLUR
Suffolk, VA
2019 JLU Rubicon
Oh Jesus, I just re-read that you wanted to hang the top vertically from only those 2 holes?
I'm gonna change my "I wouldn't do that" to ABSOLUTELY DO NOT DO THAT.
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
NOPE NOPE NOPE NOPE NOPE NOPE NOPE..
Unless you’re looking for an excuse to buy a new hard top.
Adventure.AS
Port Dover ON Canada
2020 JLUR
After re-reading your post one thing is not clear to me - can you drive your Jeep in to your garage?
If so, you likely have enough room to lift it vertically from the Jeep and park forwards with the hood under the hanging top. It doesn't need to be lifted too high to be able to drive the Jeep out from under it, although awkward walking under it when the Jeep is out of the garage.
4doorturbo
Tyler
Orlando, FL
2021 JLU Sport S
That is NOT a good idea. Those holes will not support the weight of the top, unless you plan on taking out the glass to lighten the load.
Rubi6mt
Nj
2021 JLUR 6mt
Agreed, would not hang entire top from those two holes. 4 HD eyelet screws into the joists, 2 ratchet straps equalizing load. Bought from home depot for about 30 bucks.
Jeep Wrangler JL Hanging top from garage ceiling. 20200605_173232
Ogre_FL
Cooks Bayou, FL
2018 JL 2 Door Sport S, 2021 Gladiator 80th
I dont hang the whole thing off those.
I do lift and hang it using them, splitting the load with Topsy brackets in the back.
Jeep Wrangler JL Hanging top from garage ceiling. 20200329_112313
Jeep Wrangler JL Hanging top from garage ceiling. 20190525_130331
