GMRS Antenna Cable Run
nU7OuxIx
Chicago
I installed a GMRS last weekend and put the GMRS unit in the glove box. I ran the cable across the cabin to the drivers side, through the little grommet, under the hood and to the passenger side where the antenna sits on the cowl. It turned out OK, but when I close the hood, it's a bit tight on the cable. I can still wiggle it with my fingers when closed, but wonder if this is going to be an issue later on.
What are your thoughts? Should I be looking at running it differently? The cable is run between the rubber hood seal and the cowl in that little tray.
Thanks!
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Thanks!
It might be alright. Can you provide some pictures of what you're looking at?
nU7OuxIx
Chicago
Attached are some pictures. When closed looking down on it, it looks pretty tight. But with the hood closed, I can still push and pull the wire pretty easily without scraping insulation off.
Jeep Wrangler JL GMRS Antenna Cable Run 20220504_125114
Jeep Wrangler JL GMRS Antenna Cable Run 20220504_125120
Jeep Wrangler JL GMRS Antenna Cable Run 20220504_125151
Jeep Wrangler JL GMRS Antenna Cable Run 20220504_125215
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
That RG cable is layered with the outer coating, a braid, dielectric, and then the center conductor.
The risk of it being pinched in there is egging the dielectric and then it cracking over time. However, this looks like it'll be fine for a long time like it is. Just check on it from time to time.
If it's a real concern, you can always use a file and give it some relief right there where it's at and then use some touch-up paint and it'll be perfectly fine.
I'd roll with it.
nU7OuxIx
Chicago
I'd roll with it.
Awesome, thank you!! I'll keep an eye on it in the mean time!
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
I'm rewiring my GMRS today. I currently have my radio mounted on the passenger side of my center console. The RG-8x cable runs through my Goose Gear full platform, to my tailgate. The half-wave antenna is mounted to my Smittybilt HD Tire Carrier, which provides an atenna mount on both sides of the tailgate.
I'm leaving the RG-8x in place, since I plan to stack a small CB onto the GMRS. Then I'm running a shorter RG-8x cable to the driver's side cowl, and mounting the half-wave antenna there.
Once I reroute the GMRS antenna, I'll move the existing RG-8x cable to the CB. I already have a mount for my Wilson Flex antenna on the tailgate.
This thread has me worried about the thicker RG-8x cable getting through to the driver's side cowl, but as mentioned, if I need to, I'll cut/file away the cowl where necessary to avoid damage over time.
Here's what I have now, will post "after" pics when I'm done.
Jeep Wrangler JL GMRS Antenna Cable Run 1653240119393
Jeep Wrangler JL GMRS Antenna Cable Run 1653239461146
Jeep Wrangler JL GMRS Antenna Cable Run 1653239474694
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
I would just use it until you have a problem, then replace the cable with RG316, which is what comes with most of the Diamond or Comet antenna mounts for 2m/70cm. More attenuation, but for such a short run it isn't going to be bad.
donmontalvo
Don
Livingston, TX
donmontalvo.com
Interesting, thanks for sharing, always stuff to learn!
Didn't know there were options beyond RG-59 and RG-8x.
Agreed, I'll go ahead with the RG-8x for now, even if I have to trim the cowl to prevent pinching. Will see how that goes.
I'm trying to run the cables in a way that minimizes interference, which is why I hate to run CB/GMRS cables under the dash.
donmontalvo
Don
Livingston, TX
donmontalvo.com
Ok so looks like the cable doesn’t get crimped so shouldn’t have to change.
I installed the driver’s side cowl mount and tested the Half Wave and the Stealth/Ghost antennas.
I used a Surecom SW-102 SWR meter. How do these measurements look?
Half Wave antenna
Ch: Freq Watts SWR
1: 462.565 6.45w 1.09
7: 462.715 6.58w 1.09
15: 462.552 57.27w 1.59
22: 462.727 56.65w 1.59
Ch: Freq Watts SWR
1: 462.565 4.30w 1.04
7: 462.715 4.31w 1.04
15: 462.552 45.27w 1.76
22: 462.727 46.25w 1.75
Does it look like I’ll need to do any trimming on the Half Wave? Or are these numbers ok?
Jeep Wrangler JL GMRS Antenna Cable Run 5D0608AF-0801-4AE6-9DC3-76E0C760F4D1
Jeep Wrangler JL GMRS Antenna Cable Run 1322F4ED-76D4-4AB1-99F6-0B8046F406F6
smokeythecat
There are two reasons to be concerned about SWR. One is efficiency. An SWR of 1.6:1 is still nearly 95% efficient. The other reason is to protect the final stage amplifier in your radio. I'm not really a UHF guy, which is what GMRS is, but I have always gone with the rule of 1.5:1 or less being perfectly fine. And that is with radios that have little internal protection against high SWR. You look good to go. I'd start being more concerned with an SWR higher than 2.0:1.
But if there are any real RF engineers here I'd love to hear their takes.
nU7OuxIx
Chicago
Before you do any trimming or filing, I think I fixed mine the other day. I ended up loosening all the bolts on the cowl and pushed it back as much as I could while tightening the bolts. It gave me enough room so that the wire can easily move now and I'm no longer concerned about it pinching.
Just something to think about before doing something more complicated.
donmontalvo
Don
Livingston, TX
donmontalvo.com
I got lucky, the RG-8x cable didn't get pinched at the cowl. I haven't zip tied it into place yet, not sure yet what route to take under the dasy. The RG-8x is shielded better than RG-59 but I still want to find the ideal route that keeps it reasonably away from stuff that might still interfere.
donmontalvo
Don
Livingston, TX
donmontalvo.com
I forgot I also have a Wouxun ANO-050G Mobile GMRS Antenna. So I mounted it and ended up trimming 1/8” twice from the base.
A quick test with a buddy, this one seems like the best one. Here are the numbers I get:
Wouxun ANO-050G
Ch: Freq Watts SWR
1: 462.565 5.06 1.00
7: 462.715 5.01w 1.00
15: 462.552 42.53 1.29
22: 462.727 41.17w 1.30
Going on a weekend group trip to Mt Washington and Jericho Mt, will shout back with results when I return.
Jeep Wrangler JL GMRS Antenna Cable Run 88DF859A-7408-4A32-9866-144A074E139C
David P.
Durham NC
2021 JLUR
So a new midland MXT575 has a whopping 50 watts - does that mean there’s simply more transmitting power?
Or does that also mean more watts will run theu connections, so the antenna will need to be further away from passengers to be safer?
Is there a higher risk of electrical fire?
