nU7OuxIx
I installed a GMRS last weekend and put the GMRS unit in the glove box. I ran the cable across the cabin to the drivers side, through the little grommet, under the hood and to the passenger side where the antenna sits on the cowl. It turned out OK, but when I close the hood, it's a bit tight on the cable. I can still wiggle it with my fingers when closed, but wonder if this is going to be an issue later on.
What are your thoughts? Should I be looking at running it differently? The cable is run between the rubber hood seal and the cowl in that little tray.
Thanks!
Thanks!
