mm5300
- Mike
- Jun 12, 2024
- Atlanta, GA
- 2024 JL 4xe
I've run the wire through the firewall and I've been trying to find a battery and an ACC fuse to tap into for this dash cam. The dash cam has a parking mode that needs the battery and has a voltage check so it doesn't drain the battery.
I've been looking around at the forums and most people mention F52 (front socket plug) for ACC and F43 (rear socket plug) for battery. However, when I try to use the fuse taps I have, and seem to be all I can find, I can't connect them both without finding a fuse tap with the wire coming out of the other side. With it the way it is, I would have to cut the fuse box cover to make it fit. And actually, even using the F43 slot where it fits in the fuse box, the fuse tap is somewhat tilted because the wire pushes against the large box fuse next to it.
Does anyone know of a different constant battery fuse that I could tap for the parking mode of the dash cam?
