Front LCA installation help
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Torquing to spec, 190ft/lbs, on the ground under the Jeep is a tall order. I paid the price for a few days after it did that on mine. I would “try” to support the axles on jack stands to give yourself some more room to tighten. Otherwise put on a weightlifter belt or something before you shoot your inerds out of your body:angry:
Damn straight. Even with a 3ft torque wrench 190ft/lbs was a serious effort to do at ground level - just not enough room to get proper leverage. After the first bolt I noped out and called a buddy to bring over his ramps....
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
I hang it from the frame bracket and torque from the side. Plenty of space for activities.
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Love to see a pic of this. I rolled around a bunch trying to figure out a better way. And couldn’t figure one out.
Just put a bolt through the frame bracket and drop the control arm to the ground. If you mock the control arm up and get the jam nut close you can even get super close in getting the joints in phase.
Jeep Wrangler JL Front LCA installation help 20221115_172201
Blacktip
NC
2023 JLUR XR
My goal is to set the caster angle to 6.5 degree initially, some suggest 6 degrees and others suggest 7 degrees, so I am aiming for in between.
Take your Jeep to an alignment shop that does free diagnosis with computer print out. Up to you if you'd like them to set the toe since they are taking the time to help you out. This will help you get your before measurement of caster. Once you're back home use a digital angle finder to get your before measurement. Pick the same spot on the axle before and after the adjustable control arms are installed so you can compare. Now you can get really close on your after measurement without guessing.
Thank you very much, it is very much appreciated. I am used to working on cars, but this is my first Jeep.
Cux211
PA
2020 wrangler unlimited rubicon recon
I haven’t done them on a Jeep but I’ve done them on 2500/3500 rams still a straight axle and like said I never lifted the truck off the ground I had ratchet straps hooked up to pull both ways but found that just rolling the tire a bit was all that was needed
somedude922
McFrisco
2021 JLUR, Previous: 1984 CJ7, 1979 CJ7
This was a timely post. I put on a Metalcloak gamechanger this weekend and have the darn LCAs backwards! I need to switch them out and was trying to formulate a plan since both LCAs will have to come out. I also need to adjust caster.
Metalcloak adjusts caster with front UCAs. Can I tweak the LCAs to get my caster where I want since they will be out anyway?
Roky
Roky
3.5” lift ?
Roky
Roky
Here’s the measurements I used for 3.5” on 37s to get 6.3 caster and center the rear wheels in the wheel well, and set rear pinion at 2 degrees down to keep rear springs straight…….. and yes you can set caster with lcas…… here’s side shot to see wheels in wells……
Jeep Wrangler JL Front LCA installation help F01BCDDB-085E-42B1-9356-397B302A46B0
Jeep Wrangler JL Front LCA installation help 9FB8126C-18A2-435C-AC27-AB882AB49930
somedude922
McFrisco
Thanks! I set them according to MC spec (as close as possible)
Front LCA: 24, UCA 19 3/4
Rear LCA: 20 1/8, UCA 17 1/2
Steering is definitely flighty. I imagine I am under 6* I have not measured any alignment specs yet. I had to get it all close so I could drive to work this week. I plan on dialing it in this weekend.
What is the best way to switch the front LCAs around? I will need to have both off at the same time. How should I set up my jack-stands and such? Or I could pull one out, slap the stock one in as a place holder. That way I could do this with wheels on.
Sorry OP for hijacking the thread.
Roky
Roky
Use stock lca, it will make it easier, if both lcas are out it’s more work…..
somedude922
McFrisco
Got everything lined up. Thanks again for the measurements. Here is my alignment print out. Aside from a right pull everything seems good.
Jeep Wrangler JL Front LCA installation help 09767145-B4C6-4057-BCDF-9F908E218C6E
Roky
Roky
Sure brother , anytime ……. Alignment looks good!
